Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Will not ignite
Gas is getting to the unit and underneath, the pilot light is lit but the panels (or whatever they are called) will not ignite.
Laars lite 2
Model LD175N
Serial # Go4PF2192
  • normanleroy2 Dec 10, 2008
    It is natural gas and what I called panels are called, I believe, burners
  • rmbsk Dec 13, 2008
    when I turn up the heater dial the burner does not ignite. The pilot lite is on.
  • 33 Answers
First check thermostat is calling for heat or if gas valve fault get unit serviced
Posted on Jan 17, 2010
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
How to light teledyne laars 1 series pool/spa heater
turn on gas turn to pilot then hold down button light underneath where the small silver tube goes from the gas valve hold down lite then hold for a minute then turn to on should stay lit if not need new pilot generator
Jan 28, 2012 | Teledyne Laars Pool & Spa
My larrs pool heater will ignite,but not stay lit
If your Laars will not stay lit then the pilot generator is faulty. That is the small brass and copper piped connection near the pilot flame. It must produce 250minivolts in order to open the main gas valve and keep the gas running into the pilot burner..
please visit http://www.laarsman.co.uk for more help
Miles X
Jun 03, 2010 | Teledyne Laars Laars Lite2 Heater 400000...
We have a laars lite 2 pool heater , the pilot is lit but the unit will not fire up
With these pool heaters, there are a couple of things that you can try before you call a pro. First, make sure that your gas valve knob is turned to the on position. Secondly, you could have air in your gas line. Cycle the ignition sequence until all air is out of the line. It could also be that your gas valve is malfunctioning and needs to be replaced.
May 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Millivolt pool heater will not ignite
Most heaters do not require power for the pilot to remain lit. Is there power at he unit? If it worked yesterday and not today has anyone turned it off at the circuit breaker? If you have power turn the gas valve off for 10 minuets and then relight to see if it needed a reset.
May 23, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light wont stay lit
If this is a new item then you will need to let the gas run alittle bit longer. If this is a used item then it sounds like you are going to need to replace the flame sensor. You may have to even do it on the new item. But usually for the first start you willl need to hold the pilot down for about 1 minute to really let things heat up in there then when you release all will work
May 21, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite 2 Spa Heater
it might be the hot surface ignitor. a common problem with gas furnaces also. also, check if there is an code on your screen. it will be called an FL code. call the manufacturer.
Aug 05, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
251 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Michael Galve
Michael Galve
Craig Butler
Craig Butler
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
