Question about Rockwood XR-1712 Car Subwoofer
Getting a loud " POPPING" sound
I have two 12" rockwoods in a sealed (Obcon)enclosed. I'm running them with a "Soundstream" USA Series-305A. When I turn up the volume to around 50% one of them starts to "POP" with every recoil. Is this speaker blown??? It also makes a loud thud when I turn the ignition off. Would some one help me out? It's driving me to the brink!!! Thank Chris
  • Christian Simenec Mar 07, 2007
    Thank you, you have been most helpful...... Chris
  • 156 Answers
Switch the wires on the two speakers at the box and see if the problem moves to the other speaker. If the second speaker starts popping and the first one stops, the problem is in your amplifier. If the same speaker keeps popping then you probably have a blown sub.
Posted on Mar 07, 2007
SOURCE:
1994 saturn when trying to give it gas, it makes a ticking noise and a loud pop sound what is going on
You installed the wires wrong
Google a picture of the ignition
wires & firing order
keep in mind exhaust converters get blocked
after 12 years or sooner if you have cylinder misfires
Aug 13, 2014 | Cars & Trucks
Xl12002002intakegasketssolveswhatproblem
Hi Anonymous, popping is usually caused by air getting sucked in combustion chamber do bad intake seals leaking. Leaking exhaust gaskets can also be suspect. Remove air cleaner and backing plate, while engine is idling spray WD-40 or Brake Kleen around intake manifold to head area, if RPM's increase you have an intake leak and seals need to be replaced, also spark plugs will be burning whiter than normal. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 20, 2014 | Harley Davidson XL 1200 C Sportster Custom...
Dvc wiring diagram
need the ohms of each coil and what the amp can handle in ohms
Dec 12, 2013 | Soundstream PCS-12 Car Subwoofer
Popping noise
Check the sub with a multimeter. It should read the ohms it is rated at when you hook it to the positive & negative inputs. It its off your coil if bad.
Mar 16, 2013 | Alpine SWR-1241D Car Subwoofer
Have a 1996 soundstream reference 1000s amp 2 chan. Want to hook up 2 2011 12 inch kicker cvt woofers 4ohm. What is the best way to run this set up?
I have Ref-1000s with two Pioneer TS-W1200C 4-ohm subs bridged in series. So it is 8-ohm mono load, easy for an amplifier, long durability, less heating, low current consumption. I have heard that this amp might break if used with low impedance loads.
Mar 18, 2011 | Soundstream Car Audio & Video
93 MX6 throttle body is Popping, loud,sounds like a diesel
Sounds like the pipe/connection from the exhaust manifold to the EGR valve that is located at or near the throttle body has a leak. That would make a loud popping noise.
Jul 15, 2009 | Maybach 62 Cars & Trucks
Looking for anp
Rockwood is available here in the US, but it might be a brand to stay away from! That company popped up after Rockford Fosgate and Sherwood became nameplates in the industry, and caused some confusion. Now they offer 5000W amplifiers with circuit boards the size of cell phones. GARBAGE!
The amplifier that is worth anything that you may have seen is Soundstream. Their tarantula line was so popular, when it got bought out, the new company retained the logo for all its amplifiers.
Look at www.soundstream.com for recognizing which amplifier it was. Im pretty sure that line now is pretty plain, but a limited ed. or older tarantula amplifier has a big spider on the front.
It is the only spider logo I know of in the 18 years I have been in the biz.
Here is an older model tarrantula...
http://ampguts.realmofexcursion.com/Soundstream_Tarantula_5004/outside2.jpg
It is no longer available in this particular shell (see website for details). So that may be why you were told it cant be purchased here (anymore).
This is a nexer version with the logo etched instead of 3d.
http://www.lightav.com/car/soundstream/tarantula.jpg
Hope this helps!
Jan 04, 2009 | Rockwood Black Spider 2 Channel Car...
Soundstream amp blows fuses
try to disconect the speakers and turn the amp on and tell if it still blows the fuse
Dec 28, 2008 | Soundstream Car Audio & Video
Rockwood XR-1712 Car Subwoofer Logo
309 people viewed this question
Top Rockwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Rockwood Car Audio and Video Expert? Answer questions, earn points and help others
