2000 Toyota Celica Logo
Posted on Dec 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
REGARDS TO TOYOTA CELICA 2000
THANKS YOU VERY MUCH FOR YOUR INFO(TOYOTA ED).. I HAVEN'T HAD THE CHANCE TO CHECK THE MAF, MY SISTER TOOK HER CAR TO A SHOP.. BUT ONCE SHE GETS IT BACK I'LL CHECK IT OUT.. I WILL KEEP YOU POSTED AS WE FIND OUT THE PROBLEM. ONCE AGAIN THANKS.. HAPPY HOLIDAYS!!
FLACKO50
  • Anonymous May 11, 2010
    Thanks. I'd like to know what the solution was. If you could, get the diagnosis and get back to me BEFORE they fix it.
Anonymous
Level 3:
  • Toyota Master 1,861 Answers
  • Posted on Dec 23, 2008
Anonymous
Toyota Master
Level 3:
Answers
1861
Questions
23
Helped
1484385
Points
8422
I'd appreciate you letting me know! Happy Holidays to you too!
1helpful
Toyota Celica six 91 no spark after hesitation when accelerating over 2-3 months no died.
Check maf sensor. As a test, cable tie the connector to the MAF plug.
Check the repair manual also for instructions on troubleshooting
https://onlyrepairmanuals.com/downloads/toyota-celica-workshop-manual-1989-1993/
P1693 in my 2000 toyota celica
Toyota Ed,
Hi, What will be the solution for code 24 and code 15?
Please reply thanks.
Toyota Celica hesitates at cold start everyday
You know that you have a boost sensor I know you said MAF sensor, but some make and engine size has a boost sensor when this sensor goes you lack power as you described. so make sure this sensor vacuum hose is hooked up it also acts as a MAP sensor. give fuel when you accelerate
2answers
Toyota Celica 2000 GTS hatch won't unlock
Go inside the rear hatch area remove the trim panel and manually trip the hatch release.
Engine races. The engine idles at just over 1000rpms. the throttle is at its lowest setting.
Hi
it sounds like the MAF sensor, or air mass sensor same thing. also check for leaks in any air pipes, look for rips or tears in the pipes common on a car this age.
Regards
Dan
2answers
TOYOTA CELICA 2000
Go to your auto parts store & buy a can of "brake cleaner". Remove the MAF and spray it until the wires are shiny.
Do not use compressed air, that will break the wires.
BTW, the cat is covered for 8 years, under warranty.
TOYOTA CELICA 2000 ACCELERATES SLOWLY
it might be your fuel injectors. The fuel injectors have been recalled. My 2000 gts was hesitating and i had the injectors cleaned and that fixed the problem. A month later i took it in for service and was advised that there was a recall on the fuel injectors.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
