Question about Sony STR-DE445 Receiver
Reciever troubles the center speaker on the reciever clicks off during play when you bang the side of the reciever it clicks bACK ON WHAT could be causing this?
  • jbonec3 Jan 08, 2008
    i had that same problem...i took to a stereo repair shop and they told me a circuit board needed replacing which was gonna cost me $120! i told them i could buy a new sony digital receiver for $50 dollars...being that this unit is now almost 9years old i decided not to get it fixed..but i cant help but wonder if there's another solution
  • Anonymous May 28, 2008
    The problem of the center channel cutting out during play has recently ( a couple weeks) struck me too, only I don't hit the side of the receiver to get it back, but simply turn the unit off and then back on again, which works about 90% of the time.
    I got the STR-DE445 unit as a part of a HTIB package Sony was selling in 2000. It was an entry level unit, but I didn't have a whole lot of money and still wanted a 5.1 DTS solution. I've had this receiver since then and it's been a champion to say the least. I've moved three times, have upgraded speakers, and have had a son who is all too good at finding daddy's electrical gear, and this is the first time the unit has had as much as a cough. In all fairness to Sony, it's been one heck of a performer.
    When the audio clipping first started I was bugged, but then when I thought about it I've certainly gotten plenty of use from this unit, and nothing really lasts forever. Besides, with the technology that is available today in most of the entry level to mid-range units that cost just as much as this did when I bought it new almost ten years ago, it doesn't make sense why one wouldn't simply put this unit to sleep and upgrade. Rather than spending any sort of money to fix a discontinued piece of equipment, spend $600 bucks and snag the Sony STR-DG920. That's my plan if I can find one. They debuted on the Sony website today and are already out of stock.
  • 2,130 Answers
Slapping the unit causing the missing sound to come back tells me that there is something loose in the receiver. This could be a bad solder joint or dirty switch contact. Vibrations, such as sound, could be jarring the bad connection and causing the sound to cut out when it was just working a few seconds before. I don't believe you have a bad part in the receiver. When a solid state device fails, its gone for good. Again, it soulds like a bad connection. Finding a bad solder joint can sometimes be difficult. What you need to do is take the cover off so you can see the bottom of the PC board and using a good light source and magnifying glass, look for the bad connection. You can try running the receiver with the cover off and using a plastic pen, try pushing down on the PC board and see if you can make the sound cut out. You may be able to isolate the area by where you push on the board. Look for loose wires too. While you have the receiver open, buy some electrical contact cleaner in a spray. Radio Shack used to sell this as TV Tuner cleaner. I don't think they carry it anymore though. Spray the switches and rotate them back and forth several times. See if this resolves the problem. If you do find a bad solder joint, all you have to do is resolder it with some new solder. Make sure you do this with the power OFF. You're not looking at a big bill here. It's an easy fix once you find it.
Good Luck.
- Jim
Posted on Jan 28, 2008
Kenwood KR-V7080 reciever will not play through speakers.I can still plug headphones into the reciever and get audio but not through the speakers. Tested the speakers and they still work.
If the speakers used to switch off when the headphone plug was put in the socket, suspect the socket it goes into as being the trouble. It is clearly not connecting the speakers, when the headphone plug is removed.
Aug 17, 2015 | Kenwood Audio Players & Recorders
The front center speaker bangs then it hisses constantly never stops but the radio plays fine
The noise may be from distortion cause by interference. It may be from the wire. Trace the wiring of the speaker to see if there are loose connections at its back or exposed conductors. Check if there are magnets or power cables crossing on the path of the wires.
May 19, 2011 | 2004 Nissan Quest
My Amana LW4303W washing made a loud bang noise,
Hi.
You have broken the drum bearing, it is the part located at the bottom of the tub, the drum bearing if fixed at the back of the drum.
Here all parts and diagrams for your model.
Regards,
Nov 14, 2009 | Washing Machines
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
REAR AND CENTER SPEAKERS WILL NOT PLAY
rear and center speakers will not play...................are you in the 5.1 channel input, or one of the others? either way, start by making sure that your center channel is set for normal mode (instead of a wide or a phantom mode) this silly setting can cause all kinds of trouble shooting nightmares especially particular to the 5.1 input setting. best reccommended to select the 5.1 input option and do a "t.test" on the system to ensure that all speakers are indeed wired and properly recieving some signal..... the rest will flow from there..... I have also noticed that in particular sound modes, the system is extremely finicky about the connections..... if you are using the 5.1 option, you need to be sure that something is plugged into the inputs on the back (regardless if they are connected to anything) the system seems to prefer when all ports are filled. hope this helps..... i realize that it has been a while since this question has been posted, but let me assure you, that some of us are still rockin those sava systems..... still by today's comparison, it is difficult to beat the sound quality and oh my the bass!!
May 09, 2009 | Sony HOME THEATER SYSTEM System
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
Maytag HAV4657EWW tub bangs during spin
This washing machine has self-leveling rear legs. Tilt the machine up on the front legs and you'll hear the back legs drop down to re-level itself. Center the basket and restart.
Mar 10, 2009 | Maytag MAT13MN Top Load Washer
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Center channel
Back to basic to advance:
Be sure you have all speakers connected correctly behind the receiver.If you center channel don't have any sound,it could be 7 different issues,but you could try to just hook up your center channel to either the right or the left speaker output to be sure the center channel speaker does work.
Check your the speaker wiring tip(if there is any),i will use just the speaker wire go straight to the center speaker output,go to the receiver to change it to pro-logic or dolby digital and of course you should put in a dvd in the dvd player to have a good quality movie to play the dialogue through the center channel for you test.
If you have tried the above step and still have no sound,you might consider hiring a troubleshooting master to take care of your issue.
Let me know what you need!
solutiondoct
Nov 05, 2008 | Pioneer VSX-455 Receiver
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
Sony STR-DE445 Receiver Logo
120 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
