Question about Philips Magnavox 9P6034C 60" Rear Projection Television
When tv is turned on the picture is distorted.thought at first that one of the bulbs was bad.took the screen off and all bulbs are lit.the red bulb looks distorted.has the bulbs got to go out to be bad.what other parts should be checked?
  • Philips Master
  • 3,459 Answers
Can you explain distorted in more detail?
Does the screen look 3D?
Can you adjust the convergence for both the blue and red colors - up - down - left - right?
If not the convergence chips and resistors are shot and should be repalced.
If however the screen is shrinking and expanding that is a different problem.  You can get a repair kit from www.TvRepairKits.com for this model.
Posted on Dec 12, 2008
I have a samsung dlp 61 inch tv...older model...just replaced the lamp but the temp light remained lit....then two weeks later the tv will only turn on after several attempts and ever since it has been off...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture...
Lets try an error code operational checl. Unplug the tv and plug it back in. With the standby LED on press and hold the MENU and DEVICE/INPUT buttons for 5 seconds. The LED will flash a certain number of times pause for a while and blink again. Count the blinks before and after the pass, then post it here so that I can tell you what the problem is
Mar 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Magnavox 50" DLP Tv power light comes on but then i hear a buzzing noise and then two red lights come on the tv. at no point does the picture turn on during this time. Can you please give me a possible...
Your bulb is burned out. I have had the same problem. It seems this television has an overheating problem--and short bulb life. I have had our 50 Magnavox dlp for two years and just put in the second bulb before Christmas. You can buy the bulb from a dealer on ebay for $99 and install it yourself. I is not in the housing so you have to carefully take out 4 screws and replace the bulb without touching the face of the bulb. To buy the one from Magnavox with the housing is much more expensive. I think the first time my husband replaced the bulb it took about 45 minutes--this time it took about 20.
Dec 16, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Rca projection tv has no picture or osd
Check the bulbs. If one is burned out, you will get this problem. The bulb is easy to change but will run you about $300.
Feb 10, 2008 | Televison & Video
Dim picture from one broken lamp??
The red CRT is most likely not the culprit. If water got on to any of the boards such as the red CRT driver board it could damage it wich also at the same time can load down voltages (200 volts etc) that can have a global affect on the other CRT's. Changing any on the CRT's by the average consumer is NOT recommended because you are dealing with a device that requires 30 KV (thats thirty thousand) volts to make it light up. Take these as warnings and consult with a technician.
Dec 08, 2007 | Toshiba 65H84 65" Rear Projection HDTV
Blue area near center of screen
Uh Oh! blue screen of death. Your light engine has warped a little from overheating and is distorting the picture.
My suggestion to you is to get on the phone with hitachi and start complaining, then keep complaining until they agree to pay for it. You may have to get the problem diagnosed by a pro before they agree to pay for it though.
Oct 08, 2007 | Hitachi 50V720 Television
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
