Question about Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 Issues
Thanks for the response below. What is a kettle lead and 3 amp kettle plug? Thanks in advance for any help ! I had the same problem, I changed the kettle lead i was using and it now works perfectly. I now use a 3 amp kettle plug.
  • browncharlie Dec 21, 2008
    also have the dv10. amazing movie monster overall.  i am having similiar issues with mine. Whenever I go to hit the power button, the temp and lamp lights flash on for a second, but the projector won't produce any power. The fan just sits there spinning.  I don't know what the fix is?  I thought initially it was a burnt out bulb, so I replaced it with a new replacement, and it still won't do a thing.  I did notice that when the night it stopped working, there was a low to medium kind of popping sound (that's why I was sure it had to be a defective bulb) coming from the projector, but that apparently isn't it either.  Any help?  Tchag, can you tell me more about what a 3amp kettle plug is and where to buy one?  I searched ebay, amazon, and monoprice and can't seem to locate these.
    THANKS ALL FOR ANY HELP IN THIS MATTER,
    AKM
My optoma movietime DV10  projector is making a buzzing noise than it shuts off after about five minutes
Posted on Dec 20, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
Change the lead that came with the system to another one, i am not sure if it was the new cable or the step down in the amp that I used, but it did the trick
Posted on Dec 10, 2008
Why won't my Optoma DV10 projector won't turn on?
On an Optoma DV10 if its not the lamp timer, then it might be a cooling fan that needs replacing. Take out the old one, and look-up its part number online. If you don't feel confident taking it apart, have a qualified person do this.
May 23, 2014 | Optoma MovieTime DV10 DLP Projector
I have my optoma DV10 hanging out all over. I see 2 fans. Do you know which is the cooling fan responsible for the 2 blinkink lights? I also can not locate the heat sensor
this tape is a ribbon wire that connects to the lower half of the unit.. you must push it back into its connector or the entire thing wont work..
Jan 08, 2014 | Optoma MovieTime DV10 Multimedia Projector
Optoma DV10 randomly shuts off completly during a
check the power timer settings and put it to disable setting, Or avoid anything that cover the exhaust, fan if the problem occur get assist to the technician.
Oct 22, 2009 | Optoma MovieTime DV10 Multimedia Projector
DV10 Issues
change lead to 3amp lead, seems to have done the trick with me, i am not sure if it the step down from amp on fuse or if it was a better lead that did it.
Nov 26, 2008 | Optoma MovieTime DV10 Multimedia Projector
DV10 Color Wheel Replacement
Hello, the information is as follows:
Part no: 70.18r26g01
Cost: 129.00 + shipping
Model :Optoma DV-10
Contact no: (408) 383-3710
You may also contact the "out of warranty" repair department at 888.942.2929.
Glad to help.
Aug 18, 2008 | Optoma MovieTime DV10 Multimedia Projector
Bad color wheel on Optoma DV10
Yes, you can replace the color wheel yourself if you are handy with a screwdriver.
Jul 19, 2008 | Optoma MovieTime DV10 Multimedia Projector
Service Manual
I could obtain this Manual from Optoma for you as I am in a position to obtain these sort of things.
Kindly refrain from locking a rating if the problem isn't solved first time round.
May 07, 2008 | Optoma MovieTime DV10 Multimedia Projector
Unable to Connect DV10
Hello!
Which are laptops? I use IBM R40e and HP laptop and I usually connect them with DV10 for conferrence. It's well! I have just a problem with Asus EEE. It unable connetc with DV10. I try use Video jack to connect. Result: It can display but the quality is very bad. Now I try to find another way to connect them together. Some information to share with you. Thanks you!
May 03, 2008 | Optoma MovieTime DV10 Multimedia Projector
Power prob
blimey, these dv10s seem to suffer big from this problem.
check air filters,fans running.
if no input pj may shutdown by itself anyway
try connecting an input signal to see if pj keeps running
Feb 15, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma MovieTime DV10 Multimedia Projector Logo
371 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
