Question about HP Vectra VL800 PC Desktop
Error code 0300 on disk drive A
I tried to get the desktop up and running but it will not boot, message in left hand corner of screen says operating system not found tried setup but it stalls then summary comes up saying error 0300 disk drive A. BIOS settings are configured to what they should be. I lost the original windows installer disk so a friend lent me a copied disk. Would this cause the problem I have. I would be very grateful for any advice as not that much trained in computers. Thanks
    Top Expert:
  • 4,961 Answers
0300 Flexible disk drive (A) boot error POST has detected the flexible disk drive (A) reported an error during its self-test.
To correct this:
1. Verify a diskette can be properly inserted and removed from the flexible disk drive.
2. Verify the flexible drive type configured in the Setup utility matches the flexible disk drive installed in the HP Server.
3. Verify all data cables and power cables are firmly connected.
4. If the problem persists, your flexible disk drive may need to be replaced. Contact your service representative.
Posted on Jul 13, 2012
SOURCE:
  • 101 Answers
SOURCE: won't boot, says insert disk & press enter.
this means that the operating system is missing
and you will need to reinstall windows
try to borrow a disk and reinstall windows
hope this help
Posted on Sep 19, 2009
Testimonial: "Thanks, answered all my questions."
SOURCE: added a new hard drive
You can't transfer the operating system. You have to reinstall it on the new hard drive. Most of the time the disks that come with a computer are just restore disks. Without the restore partition that comes on the hard drive that came with the computer, those disks are usually useless. Or if you want, you can keep both hard drives, and just setup the jumper settings on the hard drives so that the old hard drive is the primary, and the new one is the secondary. Then you will still have the operating system and you will use the new hard drive for storage.
Posted on Apr 21, 2009
SOURCE: operating system wont load?
hey if i reinstall my windows the hp recovery hard drive have the drivers inside? or i have to download the drivers for this pc and burn them in a cd and after reinstalling install the drivers ethernet video audio etc :D ?
Posted on Mar 12, 2008
MUKHTAR
  • 2022 Answers
SOURCE: I have a dell desktop running Wondows XP 2000.
There are lots of possibilities like faulty ram or may be virus in the system or may be the windows file is corrupt try to repair the windows installation. or take the backup of system and the format the system
Posted on Jan 21, 2010
TIPS72
  • 369 Answers
SOURCE: windows installer error
DID YOU GET THE RESTORE CD WITH THE HP SYSTEM IF YES THEN PUT THE CD IN START YOUR COMPUTER CHOOSE BOOT FROM DVD AND THATS IT IT WILL RESTORE IT OR ELSE U TRY PRESS FUNCTION 8 LIKE F8 AND CHOOSE LAST KNOWN GOOD CONFIGURATION. IF DOSENT HELP U HAVE TO GET THE GENUINE wINDOWS DVD AND INSTALL YOUR WINDOWS AGAIN
Posted on Mar 03, 2010
No operating system found
The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove the hard drive and reseat (reconnect). Check BIOS. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 13, 2012 | Computers & Internet
When i turn my computer on i get a black screen with a light flashing in upper left hand corner
Try booting your system into safe mode by holding f8 while booting up.
Mar 23, 2011 | Compaq Presario 5000 PC Desktop
My pc will not boot saying "setup is inspecting your computer's hardware configuration. . .
I think you may have left the operating system cd in the cd drive - this message appears when your pc boots the cd before it installs the operating system. So check your cd drive and remove any disks
Jan 09, 2010 | Compaq Presario 5000 PC Desktop
My dell desktop doesn't start or boot from cd rom
Basically you need to go to Bios to change your "Boot device pripority". Please follow these steps to do this.
Please follow these steps to install XP on your PC.
1. Please start your PC with power button. At the very first screen, at the left down corner, you will see the button to be pressed to go to Setup i.e. Bios of the PC. For most of the PCs , it is delete button. For some of them, it is F2 also. So, after starting the PC press Del to go into setup.
2. After you enter setup of the PC, please go to Advance bios setup.
3. There you select Boot device priority.
4. here the first boot device priority should be CD ROM, then the HDD. Please see the instructions given at right down corner and select this priority.
5. After you rightly selected boot device priority as given above, Press F10 to save the changes and then press F12 to exit.
6. Now the PC will restart again, but be sure that you put win XP cd in the drive before it restarts.
7. Now you will see a note that : press any key to boot from CD ROM, so please press any key.
8. The PC will boot from the CD ROM now , now you can follow the instructions given on the screen.
May 07, 2009 | Dell Dimension 4600 PC Desktop
PXE-E53 and 1962 No operating system found error messages
Install Windows XP and then Ubuntu
Any Linux Using GRUB (preferably) Or LILO will automatically fix all "No Operating System found etc. Problems"
Sep 11, 2008 | IBM NetVista PC Desktop
XPS 600 BIOS setup problem
light 1&2 is a memory configuration error.make sure you have the memory in correctly
Sep 06, 2008 | Dell XPS™ 600 PC Desktop
Operating system lost
Reset your HD. Uplug all the cables connected to it and then plug them back in. Then try to boot from you xp cd. Let me know how it goes.
Sep 22, 2007 | Gateway Essential 500 PC Desktop
Open Questions:
Outlook MAil Contact NuMbER {1=855={536}{5666}#[email protected] TOLL FREE This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 19, 2019 | AOL Computers & Internet
Outlook MAil Tollfree {1.855.536**5666}#[email protected] PHoNe NuMbER CUSTOMER This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Outlook MAil TelePHoNe {1-855*536*5666}#[email protected] NuMbER HAWAII This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
See all HP Vectra VL800 PC Desktop Questions
HP Vectra VL800 PC Desktop Logo
768 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
