Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Yellow residual image/smear
Set is only approx 4 years old; never had a problem until now. Recently noticed a yellowish "blob" or smear in the upper right hand quadrant of the screen. Really noticable against a white background, but blends into a color image. Stain appears constant in size/shape regardless of input. Tried running "Magic Focus" convergence reset several times without result. Even cleaned the outer glass screen to ensure it wasn't an external stain...unfortunately, it wasn't. I see this as an excellent opportunity to buy a new flat screen TV...my wife, on the other hand, insists I try to get it fixed, or tells me to ignore it. Regardless, appreciate any/all advice or help you can give. thanks!
    Genius:
  • 1,074 Answers
I think it is time to buy a new set but if you want to invest some money in it then take it to a qualified tech as these projection sets are a bit complicated.your problem is a convergence the projection lens needs to be adjusted lens.good luck and bleeeing from belize
Posted on Mar 23, 2007
Hi my Sony KDF-E50A10 has a yellow blob in middle of the screen. Tried changing the bulb and yellow blob was worse. any suggestions?
Your Optic blog has failed. The bulb will not fix that. There was a class aciton lawsuit against Sony about this a few years ago. The Optic block must be replaced(only posibble fix) Sony Rear Projection LCD TV
To fix it out of pocket would be ridiculously expensive($800+). Return the lamp or use it until the image is too bad to watch. Then treat yourself to a new TV.
I am well versed on this issue and would not recommend fixing this
Jan 10, 2018 | Sony Televison & Video
Need to descale k75.
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste
Nov 02, 2013 | Keurig K75 Black Platinum Coffee Maker w...
Need to descale it how
Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
RINSE:
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Dec 17, 2012 | Keurig Coffee Makers & Espresso Machines
I have the Sony KDS- 60A2020 60 inch TV. Recently, my picture has appeared more yellowish. Everyone on it looks like there dark yellowish or have fairly dark (bronze) sun tans. I changed my lamp yesterday...
I have a older 2006 SXRD rear projection TV. I had the same problem after the TV warmed up this yellow tint started in the corner and crawled its way down the TV. It turned out that Sony had a recall on the optic block of the TV. If you replaced the Lamp and adjusted the color this kinda sounds like the same problem. Here is a link explaining it. In this article it shows up as a green haze and blob, but in my TV it manifested as a yellow tint.
http://www.avsforum.com/avs-vb/showthread.php?t=1086180
Jun 09, 2011 | Sony KDS-60A2020 60" HDTV
Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
Dec 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
8x2 inch grainy, yellow blob
The issue is caused by the optical block. It was an inherent issue in the TV and cannot be fixed without replacing the optical block. It usually costs about $1000 for parts and labor. It is impossible to fix without the part as it is an inherent irreversible issue.
The TV starts to have problems with the optical block after a certain number of hours, you did not have this problem until much later because of limited use.
Sony did extend the warranty for the optical block parts and labor but it expired on 6/30/08. The only option you really have is to keep contacting Sony, explain to them your situation and they might cave in to paying for part of the repair due to special circumstances.
Oct 06, 2009 | Sony Televison & Video
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Yellow coloring on Panasonic TV
IN THE MENU FIND COLOR CONVERGENCE TO FIX THAT
Nov 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
