Question about Intel D865GVHZ Motherboard
My computer inter pentium 4- 2.8 ht techno. the problem is while working computer restart with blue screed wrting some physical memory error,
What is the specific error given?
what operating system?
Posted on Dec 10, 2008
    President:
  • 2,110 Answers
Try to change RAM........
'No rgb signal' to second (old) monitor
try restarting the pc in safe mode
uninstall the graphic driver restart the pc and again restart the pc
this is problem of screen resolution
Apr 10, 2014 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Why wont my computer recognize my memory
Are the RAM Modules both of the same Brand / Type mixing Brands on computers will result with this problem.
You should always place the largest RAM Module closest the CPU central processing unit.
Because both RAM Modules are of the same size this will not apply.
Try alternating the Modules to see if you get the same result.
RAM, or random access memory, is the physical memory on the computer but only holds data while the computer is on.
The benefit of adding more RAM is that it generally makes your computer faster.
Almost all new computers recognize your RAM after you install it and restart the computer, but if yours doesn't there are a few simple things to do to get the memory recognized.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Check the type of memory you have.
Computer motherboards will work only with the type of memory they are designed for regardless if the memory fits or not.
There will be either a sticker on the memory or a listing on the packaging giving the memory type and speed.
Check the computer's or motherboard's manual for the type of memory that is compatible.
Install the memory and make sure it is tight, otherwise it may not get recognized.
The memory fits into slots on the computer's motherboard.
There are tabs on the side of the memory slots to release it.
Release the memory if it is installed and put it back in by pushing it down straight into the slot until it clicks.
Restart the computer and hit the appropriate key to enter the BIOS.
The key will be listed on the screen.
Go through the menu choices by using the arrow keys.
Look for the memory listing under hardware.
Make sure all memory listings are not listed as disabled.
If so, change them to enabled.
Choose anything listed similar to "Auto detect."
Exit the BIOS and restart the computer.
Dec 08, 2013 | Gateway 556GE Intel Pentium 4 630 3GHz(HT)...
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
Computer restarting again and again and shows a blue screen with "Beginning dump of physical memory." Also when i scan the system using kaspersky internet security antivirus it got restarted and i couldn't...
sometimes it happen because you have installed a driver recently and it is creating a havoc there. try to run in safe mode and restore the configuration to the previous one.
other options, is that a memory went bad. try to read what error is telling before the beginning dump of physical memory.
if one bank of memory is bad, try running your computer with one of the banks at the time.
Apr 23, 2010 | Microsoft Windows XP Professional With...
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
What causes your video to freeze?
sounds like a hardware fault, do you get an error msg and blue screen? ide say motherboard and video card not running correctly, swap the vid card first, see if this helps,
Jun 07, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Memory dump
There are essentially two major causes of the physical memory dump screen: Running way to many programs at once, errors in the Windows registry.The first cause can be fixed rather easily. Simply run fewer programs or purchase additional RAM or processor upgrades. Your computer is running past its specified limits. But keep in mind the blue screen of
death should happen very infrequently. If you see the physical memory dump blue screen more often then the problem is errors in the Windows registry.This is a more abit of a harder problem to deal with. The registry is the most important component of your computer. The registry contains settings and information to run all software and hardware on the computers. When there are errors in the registry it disrupts the computers ability to communicate. When the system cannot compute, it freezes up and displays the Windows blue screen.
I found a registry cleaner that is free and works rather well. It is named cCleaner, has been around for some time and did I mention FREE...Download it from thelink below run it should clean up your registry...where good men fear to tread.
http://www.ccleaner.com/ccleaner-20
good luck, please leave a rating...thank you
May 04, 2009 | Intel Computers & Internet
I have IBM p6 motherboard with processor Intel 1.8ghz/256/400/1.75v Processor had demaged. I replaced with Intel 1.8ghz/512/400/1.525v When I starts the system it gave error "0167 no processor bios...
I suggest this is not going to work.
1.Your motherboard is supplying 1.75 DC volts of electricity to the processor socket.
You have installed either a SSpec number SL68Q, or SL62P,
Intel Pentium 4 processor. (The sSpec number is on the top of the processor case)
These Intel Pentium 4 processors use 1.425 to 1.525 DC volts of electricity. If you haven't already, you are going to burn this processor up.
Also, the Intel Pentium 4 that you had before, is based on the Willamette Core. (180nm) These earlier Pentium 4's did not have HT.
Hyperthreading Technology.
The Intel Pentium 4 you have in it now, is based on the Northwood Core. (130nm) These Pentium 4's come with HT.
Even if you could go into your BIOS Setup utility, and change the CPU voltage, and lower it, the HT in the processor you have now, wouldn't work on this motherboard.
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply -> Processor)
You won't be able to lower the voltage in BIOS Setup, for this processor. IF you did, then you would change the Front Bus Speed, and the ram memory wouldn't work.
Solution?
Obtain an Intel Pentium 4 processor, that uses the Socket 478 processor socket, has a 400MHz FSB, and is based on the Willamette Core.
Here is a list of Willamette Core, Intel Pentium 4 Microprocessors, that will work,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#.22Willamette.22_.28180_nm.29
Apr 13, 2009 | IBM (25P3294) Motherboard
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
Restart pc ...when work is going on suddenly appear blue screen
This happens sometimes, but it's not very common.
Did you update any drivers recently?
Have you added any components to the computer just before this started?
You may have a faulty memory "stick". This is a link to Microsoft's Windows Memory Diagnostic. Follow the instructions to create a bootable CD, boot the CD and let it run and see if there are any errors.
Feb 07, 2009 | Intel DG31PR Motherboard
Intel D865GVHZ Motherboard Logo
41 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
