posted by MrRodney58 on Mar 01, 2007
I have a kenmore upright, Progressive , Direct drive with itelliclean.
I replaced bag, cleaned all filters , replaced all filters properly , all compartments are closed securely and correctly.
The brushes are spinning but the suction isnt working at all. Thank you in advance to your prompt response.
Rodney Stafford
Comment by MrRodney58, posted on Mar 01, 2007
I have figured it out!!!! It was the Intake air flow fliter. It has a airflow direction. It is located in the back bottom of vacuum. I had it in the wrong direction. !! The second I put it to the proper direction it worked perfectly!
Best Solution
posted on Jun 13, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I took out the air flow filter at the back of the vacuum and turned it on, somehow the clog cleared. Then I put the filter back in and it works perfectly! Barb
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Kenmore 35912 / 35913 Progressive
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Repair Service
Find Vacuum Repairman Near You:
Find Parts
