Question about Maytag Ovens
Maytag electric wall oven trouble codes
Have a Maytag electric wall oven and trouble code "5A6" in red and  "6ATH" in normal LCD color. What does this indicate??
  • 146 Answers
SOURCE: F2 code and consistent beeping with my Maytag Electric Wall Oven model CWE5800 or CWE4800
The F2 code indicates a stuck relay. You will have to replace the relay board. It may be a stand alone board or it may be part of the ERC Electronic Range Control. If you know how to check you won't have to call a tech.
Posted on Dec 21, 2007
localwonder
  • 6784 Answers
SOURCE: oven will not turn from top panel electric panel is stuck on 5a6
Unplug this unit for 3 minutes. if the control fault still exists after the 3 minute reset, replace the affected control board.
Posted on Jun 03, 2009
localwonder
  • 6784 Answers
SOURCE: we have a gas maytag gas wall oven that is getting
F3
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
F5
Watchdog and hardware conflict
Replace clock (ERC).
Posted on Jul 18, 2009
jumptrout51
  • 3361 Answers
SOURCE: My oven will not move from SAb o 5A6 and buttons
You have inadvertently entered the Sabbath Mode.
Try holding the clock button for 5 seconds to clear it out.
Posted on Dec 12, 2009
Testimonial: "Thank you so much!!!! Thought I would have to pay for a repair call. Merry Chirstimas - you helped me save for Christmas."
  • 910 Answers
SOURCE: The other evening there was
The display is Sab which indicates it's in Sabbath Mode.
Press and hold the Clock Button for 5 to 10 Seconds to deactivate.
If this doesn't work then just let me know.
Posted on Jun 24, 2011
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
Sep 25, 2012 | Frigidaire 30" Built-In Single Electric...
In trying to change clock did something wrong and now will not do anything, screen showing 5A6 6ath. what can i do to fix?model#mew5527ddb16 serial# dx2614846
power down the unit at the circuit breaker for an hour or so and see if this clears the memory,otherwise try pressing stop/cancel or any combination of these types of end buttons at the same time to cancel the error message
Jun 30, 2011 | Maytag Ovens
What distance does the back and sides of the wall oven need to be from the other kitchen cabinets and drywall? What is the voltage and wattage of wall oven? What do the five colors, blue, black, green,...
the installation instructions are in the user manual and the wiring must be done by an accredited , qualified electrician
do anything yourself and the warranty is void
Aug 14, 2017 | Ovens
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag 24 " wall oven gas trouble code F5
Hi ngwhite,
The trouble code F5 is a Watchdog and hardware conflict. You need to replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Aug 02, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
LCD displays trouble code F1 alternating with F7. Serial # is MEW6627BAB
Hi
Thanks for using FixYa. Error F1 in your Maytag Electric Double oven means that the control panel has gone bad and to resolve this issue it should be replaced. Unfortunately there is no other way it can be resolved. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 25, 2010 | Maytag MEW6627B Electric Double Oven
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
Its a Maytag wall oven and I need to replace the operating panel
usually you take off the handles with screws and the front panel is screwed to the door or held on by clips or brackets.
Jun 18, 2010 | Maytag Appliances 27" Electric Double Wall...
Dec 12, 2009 | Jenn-Air JJW7530DDS Electric Single Oven
Oven will not turn from top panel electric panel is stuck on 5a6
Jun 02, 2009 | Maytag MEW5527D Electric Single Oven
Open Questions:
Ovens Logo
35 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
