Tower intermittently loses power
My tower loses power and I can't seem to figure out why or what to do. I don't have to be using the computer. It can be turned on and not in use and and will suddenly turn off. The only way to get it working again is to unplug the three-pronged plug from the back and then plugging it and unplugging it until it comes back on. Sometimes this has to be done more than a dozen times. I tried the method on the power strip end, but that seems to have no effect on it. The only time it shuts down consistently is when I run a full Norton scan every Friday. Each time about 20 minutes into the scan it shuts down. I don't want to invest in any new cords, etc. until I'm pretty certain what the problem is. Thanks. shortly after bootup the hard drive lose power, the power on/off led blinks, the monitor shuts off, the hard disk led lights are on constantly. pressing the power off button doesn't turn the pc off. what i do was to move around the tower case's wires by pulling and pushing it lightly, then the pc begins to boot normally. the problem occurs at different time intervals shortly after a normal boot and sometimes while booting. which causes the problem?
  • jrbodkin Feb 02, 2009
    I have a very similar problem with Dual 1.42 G4 (FW800) where the system crashes after the screen lighting, the chimes sounding and then crash. I usually disconnect the cord at the back, reset the MPU and remove/re-install the battery and then try again. Can happen multiple times (one time started normally after 31 times, another still did not start after 80 times) Many times just removing the cord will allow it to restart. Last two times, the only way to have it restart is to completely remove power for a couple of hours and then restart as before. When it is operating now, there is a slow throbing hum coming from the unit. I don't know whether to replace the power supply (it is working at the moment), replace the battery again, or look at another failed component such as the front panel board. Any suggestions?? Please!!
    Thanks, Jim jrbodkin@comcast.net
    Scholar:
  • 56 Answers
I think you have a problem in you power supply sir try changing it or try separating your monitors source of power.
Posted on Dec 10, 2008
I have a 97 Chevy Silverado Z71 4x4. This is an intermittent problem, which makes even harder to diagnose. The problem started happening only when going around gradual curves, as with interstate curves,...
Hi Mark,
I had a similar issue with my F150. In fact the computer would respond in some cases by putting the engine into safe mode which essentially means off while driving. After much investigation, it turned out to be a faulty throttle body. Replaced it, haven't had a repeat since then 2years ago.
Had a similar issue with a Cadillac Escalde. After countless dollars and parts (through the dealer) I figured it out. The throttle body uses a sensor on the side to measure the position of the butterfly valve( essentially how open it is). This sensor is aptly called the throttle position sensor and is a potentiometer similar to what you might recall from a track car set with a little hand trigger to make the car go faster or slower on the track. Well the bed of this sensor that the connecting arms touch was cracked in several places causing the sensor to send bad readings to the vehicles computer; again losing power and shutting down. I replaced this $30 part and problem resolved. Good luck.
Nov 29, 2017 | Cars & Trucks
01 durango 5.9 not getting enough spark/intermittent spark
Are you saying you are getting a steady blue spark from the coil tower but not from the tips on the distributor cap ?
Feb 01, 2013 | Cars & Trucks
No sound from monitor
that problem is very common on a viewsonic tv replace the power supplyboard.
Jun 04, 2010 | ViewSonic VX1932WM LCD Monitor
Monitor shuts off while in use
possibly the video card needs to be reseated or the power to the card is intermittent. Also always check for loose connections at monitor and computer.
Apr 13, 2010 | Gateway FPD1975W 19" LCD Monitor
Problem with connecting power button to MB.
jsut remove and re-insert the all cable
www.compudesk.in
Sep 14, 2009 | Chenbro Xpider PC61166 Mid-Tower...
What is Mini Tower ATX Cabinet
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Sep 10, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
X trail intermittent loss of power
Suggest air intake leak somewhere. Possibly in air intake system after MAF sensor letting in false air.
Jul 25, 2008 | Nissan Z Cars & Trucks
you need a new power supply !!!!
Jul 05, 2008 | HP Pavilion 754n PC Desktop
Water tower
I had the same problem finding a Water Tower laying in the bottom of the dishwasher. Solution is to simply lift the bottom rack and insert the tower into the center-most square hole. Twist the tower with the large lip on the bottom of the rack and the two plastic pieces will overlap two sides of the square hole. It will come lose again in time, but just reset it again.
Dec 24, 2006 | Kenmore 17439 Built-in Dishwasher
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
