Question about HP LASERJET P1006 Printer
Hp p1006 wont load/feed paper
Our hp p1006 laser jet printer will not load and feed the paper. It keeps saying out of paper even though there is paper in it.
  • 3 more comments
  • Anonymous Jan 21, 2009
    P1006 is full of paper, but is says out of paper, when you click on print you can hear the printer trying to print, but nothing happens
  • Anonymous Mar 24, 2009
    there is paper there yet can't detect it frustrates me to no end, practically brand new.
  • Anonymous Apr 22, 2009
    same as everyone elses....job stays in queue & status changes to paper out...and even when paper is in...it does not start to print. I have lap top / docking station...running XP. If I do a start . run / services.msc and stop & start the print spooler....it starts printing again until the printer gets low on paper, or runs out....then it starts all over again.
  • michaelplevy May 22, 2009
    Wow. I have the same problems and boy is it annoying. I was printing a 15 page document on my new HP LaserJet P1006 and I ran out of paper at around page 10. I added paper, but the printer didn't recognize the new paper and on my computer it continued to say "Out of Paper". I tried everything... Cycling power on the printer, clearing the print queue, everything I could think of. Finally, I rebooted the computer the printer is connected to and the printer started printing where it had left off.
  • Julie Homan Jan 11, 2013
    I had a paper jam but took out torn paper it sounds like it wants to feed new paper in but nothing happens
    Problem Solver:
  • 5 Answers
I know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Posted on May 08, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 97 Answers
Shutting down and restarting the spooler servive worked for me
Posted on Aug 27, 2009
    Sniper:
  • 58 Answers
Mine does the same thing. The solution I have used on several occasions is to load it as full of paper as possible without forcing it under the guides. Lift the lid to reset the jam function, then when it begins to try to print, push the top one or two sheets of paper into the printer. If it will grab them and print then it will be ok for the whole stack of paper. Adding more paper before it gets too low also seems to help.
Posted on Jun 05, 2009
I just purchased the HP P1006 today. I encountered the same problem when I tried to print a 14 page document from my laptop (VISTA) with a wireless network connection to my desktop (Windows XP) computer which in turn has a physical wire USB connection to the P1006 printer. The printer ran out of paper at page 13 and the printer status was "out of paper". I could not cancel the document or the print queue (all docmunents) from either the laptop or the desktop. I finally powered off the printer, rebooted the laptop, rebooted desktop and then powered up the P1006 printer. The printer status changed to "ready" and I tried to print pages 13 and 14 from the laptop. Page 14 printed. I then tried to print page 13 only and it also printed fine. Clearly there are s/w problems or compatibility between the HP, XP and/or VISTA s/w products. I have had no problems with the use of my other printers (HP Laser Jet 4L and Epson C86) in this hardware/network configuration.
Posted on Mar 27, 2009
Have had my HP LaserJet P1006 for almost 3 years and just purchased my second for my home office (looks identical to this one but all black with a different number) about two months ago because this one is such a workhorse. Slower than most others but for the price? When I run out of paper, I have to fill it back up (obviously) and then I just delete all projects; usually won't let me do the last one, then shut everything down. And it fires right back up; again for the price? I make sure it doesn't run out of paper.
a few days ago, though; it had plenty of paper and it stopped printing with "Out of Paper" code on my PC's control panel. I did all the normal stuff and then some. Disconnected the power supply, disconnected from the computer, let it sit overnight and connected everything back and still nothing. Disconnected everything, took out the cartridge and flipped it around my desk cleaning it with a slightly moist paper towel everywhere I could reach (maybe it just needed some love), hooked it back up, turned it on and no...... it didn't work; but it did immediately start printing after I took Guest's advice from 2 year ago on stopping the printing spool and then starting it again.....hope this helps.
Posted on Jan 08, 2011
I just had the same problem. I went through HP's troubleshooting website and followed all the instructions. Nothing worked. Even installing a new print driver didn't work. You could hear the printer start up as if it were attempting to print, then nothing. I removed the toner cartridge, then the roller (instructions are on this web page).
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3435682&prodTypeId=18972&objectID=c01179215
I cleaned and reinstalled the roller and can now print. Hope this helps.
Posted on Jan 11, 2009
I think the HP engineers are doing a lousy job with this model. I don't have problems with other horizontal load printers.
Posted on Apr 24, 2010
Won't print manual feed
MANUAL PRINT IS ALSO KNOWN AS TRAY 1 ON HP PRINTERS. LOAD PAPER INTO THE SLOT ABOVE YOUR PAPER TRAY.
Dec 13, 2015 | HP LASERJET P1006 Printer
Even though cassette is loaded it keeps saying "add paper in cassette" and will not print
theres a sensor where the casset meets the back of the machine if it dosnt get triggered it wont see any you can trick it and it will always see paper just keep it stocked of paper
May 30, 2014 | Kyocera FS-2000D Laser Printer
Printer status keeps saying out of paper
Load paper and reset it by unplugging from power for 10 seconds then plug it back in.
Jul 16, 2010 | HP LASERJET P1006 Printer
Wont print envelopes
When you load an envelope, make sure that you move the guiding clip to fit and hold to the envelope so that is can feed the envelope and print. It is a way of manually telling the printer that what is in the printer tray is an envelope.
Feb 11, 2010 | HP OfficeJet J4580 All-In-One Laser...
HP Laser Jet P1006 printer won't reliably feed paper
try to clean pickup roller with alcogol and fabrics
Dec 18, 2009 | HP Office Equipment & Supplies
HP LASERJET P1006 Printer Logo
8,324 people viewed this question
Clive
Clive
