Question about Asko T731 Electric Dryer
Dryer internal breaker trips
My Asko dryers (4 years old) both trip their internal breakers when drying. Both have been serviced, but they still trip on a regular basis. The dryer vents are hard pipe and have been verified open. I bought a new Asko dryer out of desperation and it works fine, no tripping. The repaired dryer works fine if I leave it in the middle of the room, but when I hook it up to the vent, it trips its internal breaker on every other load. Any ideas? Thanks.
  • Anonymous Mar 20, 2014
    Hello my asko t754c dryer does not light up or run the outlet is good the breaker is good what are the common faults with this machine
    Willie
    Novelist:
  • 116 Answers
If you are using dryer sheets in the machine the filter screen may be plugged and will have to be cleaned. You can check it by placing a bit of water on the screen if it beads and does not flow through then the screen is indeed plugged reducing air flow. There could be lint and build up in the dryer's internal ducting and sensors, the machine will have to be disassembled for a complete cleaning this will also reduce air flow and cause the machine to heat abnormally.
Posted on Mar 11, 2007
SOURCE:
Dryer trips breaker after only a few mins of operation
Check to power at outlet for 220 volts
Check the breaker for the correct amperage cut off.
If the unit had an obstruction in the air flow, it would not trip the breaker.
Try running the unit with just cool air and see if it trips the breaker.
Odds are, you have a defective breaker.
Also, if the home is newly built, check the panel for loose connections at the breaker.
Or you could try a different power outlet, like the hot water heater.
If the unit continues to trip breakers on other outlets, you may have a short in unit.
Apr 29, 2014 | LG DLE2140W Dryer
I have a samsung dryer dv218ae it runs but no heat can you help me
Your heater elements may be bad and need replacement. Is it an electric dryer? If so electric dryers run a dual breaker, this means 120 volts on one side of the breaker runs the motor, the other side of the breakers runs the heater coils. Its possible the heater side of the breaker has tripped. Try turning off the breaker for 20 seconds or so then reset. 220 volt breakers can trip on one side and not the other.
Sep 30, 2012 | Samsung DV218AEW Electric Dryer
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
I have a Amana Electric Dryer NED5500TQ. When I
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
Sep 25, 2009 | Amana NED5500TQ Electric Dryer
My house circuit breaker kept tripping and
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Asko 24 el dryer does not run,no indicator light,Mod 10776110,LMBent
Check the house electrical panel for tripped dryer breaker pair. Push off, then on to reset. If breakers trip again, you have a short circuit within the dryer case--usually the heating element(s).
Aug 07, 2009 | Asko T701 Electric Dryer
Dry trips breaker
breaker is tripping from faulty insulation allowing current to ground
breakers work on milliamp current so it requires a mega meter to check the insulation
call a qualified electrician to check the unit
Sep 18, 2017 | KitchenAid KEYS750LQ Electric Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
Asko T731 Electric Dryer Logo
285 people viewed this question
Top Asko Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
jimorris77
Are you an Asko Dryer Expert? Answer questions, earn points and help others
