I have a possibly dead moniter that i need to find out if it is still under warranty
  • David Cates May 11, 2010
    What kind of Monitor is it and how long have you owned it?
    Problem Solver:
  • 17 Answers
Have you registered it or do you still have the receipt for it? If you do, contact the store where you bought it and ask them if it's still under warranty; whether it is or not, you've answered your question.
Or, go to the company's website and check what their warranty policy is.
XMinusOne@gmail.com
Posted on Dec 10, 2008
I am a technician.My Samtron 56 V moniter dead. Some time switch on when power is connected after 10to15 minutes. Please give a solution.
If you have Samtron 56 V monitor that sometimes switch ON for 10 to 15 minutes, then it is a signal of some internal device fault which needs to be rectified from certified hardware technician from monitor manufacturer service center itself. It is recommended to directly contact Samtron for hardware replacement if it is under warranty or ask to repair it.
GuruAid.com
Jun 24, 2016 | Samtron Computers & Internet
I have a Vizio Model P50HDTV10a and it suddenly went dead. Their is no led nothing. Its a year and 4 months old.
Is the tv still under warranty? possibly a blown fuse if you don't get anything at all, you could inspect the power area, but be aware there are dangerous voltages inside.
Jul 22, 2008 | Televison & Video
Hi, i need to know how to change the backlight on a neovo f-417 moniter. please help.
Though this may be an easy or not easy task I would suggest you take your monitor in to have it serviced. If you the unit is still under warranty and you take it apart your warranty could be voided If applicable. On the other hand if you do decide to do it yourself be VERY CAREFUL as these monitors can easily be damaged.
Jul 13, 2011 | Neovo F-417 17" LCD Monitor
I have got samsung 940bw moniter.when i starts my pc moniter doesn't start immediately rather it flickes(go black & white altentively) & starts after few minutes.this happens only on first power...
amityevale, If no free warranty service available to you, then visit YOUTUBE for video clips on typical fixes (repairs) to internal power supply problems that can be done by owners that "know" how to solder parts on printed circuit boards with soldering pencil and solder!! Your search terms are: "lcd monitor disassembly" and then "lcd monitor repair". Watch as many video clips as you need to learn how to DIY repair (cheapest) your unit! If after you do YOUTUBE research, you feel this response has helped you to understand the problem your unit has, then return to fixya and do comment and rate response on fixya. Also do some reading in the fixya profiles of "budmrtn" and "12fixlouie" (me) for more information. By for now. 12fixlouie
Oct 21, 2010 | Samsung Syncmaster 940BW LCD Monitor
The moniter went all black and the power button on the moniter is flashing on and off
Please disconnect the monitor from the PC and if still the monitor is blank then monitor is defective because when you disconnect the monitor from the pc you should see a message on the screen about signal like no signal etc..
Jan 29, 2010 | Dell Computers & Internet
I cant get my pc to boot up at all, I switch on and all i get is the led and cpu, chas fan running
Make sure that the moniter is securely plugged in, and the screws at the head of the moniter cable are screwed all the way in.
Also, if you modified or changed the video card of you computer, make sure that the video card is compatible
If you just got you computer, call the manufacturer to get shipped a new one, if yours is still under warranty.
Jul 02, 2009 | ASUS P5KPL-VM Motherboard
Monitor will appear to come on a "no signal" sign flashes up then the screen goes black. If you press the on off swich the green light will come on briefly then go to orange and then disappears completely...
could be a number of possibilities, lcd backlight is going bad, bad capacitors on the power board, lcd cable needs to be reseated, power board needs to be replaced. Best possibility would be to take it to a repair shop and see what the costs would run to fix it.
If its more then the cost of a new monitor then get a new monitor cause you would get the warranty.
Jun 28, 2009 | Westinghouse L1975NW Monitor
New acer 19 " moniter plug in will not turn on ?
Try other outlet, check the power cord if it contacted the monitor. If nothing happened, maybe it's factory defect, since it still under warranty, you can still change it.
Thanks
Nov 09, 2008 | Acer AL1717 17" LCD Monitor
Acer moniter model AL1916
Check the cables and the computer connection VGA outlet.
If doesn't work and your monitor is under warranty ACER will repair your monitor for free.
If not, the better option is get a new one instead of repair due the high cost.
Oct 14, 2008 | Acer AL1917W LCD Monitor
Monitor problem
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. May need to check the caps in the G-2 supply circuit. Also you may have a CRT going flakey. Just a slight G2 level adjustment may suffice also. Good luck
May 19, 2006 | Compaq MV 540 15" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
