Question about Konica Minolta DiALTA Di200 Copier
I have a Minolta Di351f. It indicates code CO500. This occurred after a power outage last night. What should I do to restore proper operation?Thanks.
  • Cynthia Heimsoth
    Cynthia Heimsoth May 11, 2010
    You'll need somebody with key operator/administrator status, or a technician. The manuals that they are given should list the code -- I suspect it's something to the effect of "the power went out", but I don't have access to the technician manuals anymore.
    Have you tried turning the copier off, counting to 20, then turning it back on? If it's just an informational error it should clear; if not, it will just pop the error back up again.
    Problem Solver:
  • 17 Answers
Look on the right side of the control panel, just in front of the display contrast slider adjustment, and you will see a small hole. Using a paper clip or similar pointy instrument, press the pushbutton switch in that hole.
The machine will go into warmup mode. When you see a small dot centered on the left side of the touchscreen display, press "3" on the keypad. This will take you to the initial mode screen, where you will see "Trouble Reset" on the touchscreen. Press it.
If the C0500 code comes back in about 60 seconds, it means that you do indeed actually have a problem with the heater lamp not coming on, possibly a blown lamp or thermal fuse.
Posted on Dec 16, 2008
I HAVE A MINOLTA Di200f/Di251f/Di351f ERROR CODE CO500
First check the right side cover where the image unit is located. Check the two latches that latch the door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jun 23, 2011 | Minolta - DI200F Printer
Minolta error code c0500
A C0500 code deals with the fuser temp. You maybe able to reset the code, by pressing the trouble rest switch. If it will not clear you will need to look deeper into the fuser unit. I don't know what model you have, so I can not go any further. Good Luck
Nov 24, 2010 | Office Equipment & Supplies
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
I am getting an error code C0500 after changing the toner. What do I need to do to get the printer back online?
Depends on the model of you Konica Minolta. The CO500 is usually related to fusing temp. It's possible that a power spike or a thunder storm that knocked out power to the building would caused this.
Jun 27, 2009 | Konica Minolta Office Equipment & Supplies
Error CO500
This error code indicates low temperature at warmup.Can somestime be reset IF you can find the reset switch.On earlier models it was behind a small panel on the innards of the machine after you open the front door.Good Luck!
Mar 30, 2009 | Minolta Di3010 Copier
My Minolta 351f is indicating service code CO 500 after a power outage last night. I've unplugged for 15 min. to try to reset but still recieve same code. Can you help?
How to reset a C0500 code.
The C0500 code can be reset following the steps below:
1. Press the soft initialization on the right side of the control panel.VERY SMALL HOLE USE PAPER CLIP
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization scree
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Dec 10, 2008 | Konica Minolta DiALTA Di200 Copier
Di351f admin code reset
has to be 8 digit could be 00000000
Sep 03, 2008 | Minolta Office Equipment & Supplies
Minolta Di351 Dialta
Try shutting the copier down and then unplugging it from the wall for 15 minutes.
If this does not reset the device, a technician is required.
Jun 10, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
194 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
