Philips fuse t8ah250vp
Hi - I have a 42PF5321D/47 philips plasma. It also went dead in the middle of viewing. There is absolutely no power and the LED wont even come on. can you please confirm that this is the same model tv that you have? Also, can you please tell me if you were successful in finding the fuse? If so, from where did you get it? Can you please email me at anandasbox@yahoo.com A millions thanks
  • shervin Mar 27, 2009
    hi where can i find the fuse t8ah250vp.??? tnx
    Problem Solver:
  • 6 Answers
Http://www.newark.com/littelfuse/0215008-mxp/cartridge-fuse/dp/42K9308
Fuse is a "Littelfuse 0215008.MXP"
8A 250V Slow-blow ceramic
Posted on Sep 29, 2009
You can buy 8A Slow-Blow fuses from Digikey:
http://www.digikey.com
Part number 283-2935-ND or 507-1216-ND
If those are out of stock, then 507-1255-ND or F2423-ND will also work.
Posted on Feb 03, 2010
  • reygomezjr Sep 05, 2013
    I have a Philips 42" plasma with the same problem. Fry's has them, manufactured by NTE, exact replacement. Part # 74-5SC8A-B
42" Plasma 42PF5321D/37 will not power on. I replaced the fuse on the power supply board with a 3 amp (that's what it looked like, but I'm not sure it was the right size because it was burned
Always replace fuse with fuse value required If fuse value is less it will burn out . If you replace with fuse that is required and it burns out then you have bad short in power supply circuit In that case check bridge rectifier
Dec 07, 2012 | Philips 42PF9630A 42 in. Plasma Television
My 42PF5321D/37 will not turn on, just flashes a red standby light. I have a Philips Plasma model number 42PF5321D/37.
Most likely a power supply problem. If it's covered under the warranty take it in right away and have them fix it. If not a good Philip's service shop can fix it. They may have a flat fee repair charge?
Blessings,
A/V Guy
Nov 19, 2009 | Televison & Video
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
42 Philips Plasma 42pf5321d/37 green light on no AV no Menu nothi
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung, Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H. 2nd more of a long turn approach to your system. You might look at a Power conditioner to ensure constant clean Voltage & current to your Set, Price I know running about $150 to $200, but this will protect your set from a Spike and under voltage swings from the 110V plug. Surge protectors only help the Spikes on the 110v Line not the Drops. Hope this helps
May 29, 2009 | Philips 42PF9630A 42 in. Plasma Television
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
May 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Jun 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
My dead 42" plasma - power problem
I went to Radio Shack and bought a 4 pack of 6.3amp 250v glass fuses (5x20)...stuck one in and it works like a charm.
Anyone know of any problem using a 6.3amp fuse instead of an 8amp one? I am thinking it just would blow out sooner...and I have 3 more I can go through until I find an 8amp fuse...am I crazy?
Jun 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips Plasma NO LIFE
I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
Dec 21, 2007 | Philips 42HF7444T 42 in. Plasma TV
Televison & Video Logo
4,147 people viewed this question
Top Televison & Video Experts
