Question about Xerox WorkCentre 432 ST Copier
Master Reset to Factory Settings - Xerox 432
Hi, is there any possibility to do a master reset on the machine to get back to the factory settings?
Thanks.
  • 1 more comment
  • Anonymous May 22, 2009
    Hi I have XEROX DC 432ST and I don't know the admin code.
    (default #22222 is not working)
    How can I reset this machine to the factory defaults ?
    .... just to be able to go to the service mode ?
  • chusky May 22, 2009
    President:
  • 2,072 Answers
Yes, you have to go into the service settings and reinitialize the memories. I have to look it up but I will send them to you tomorrow.
Posted on Dec 11, 2008
How to master reset zte z798bl
Hi @Kyle Glenn
Please follow the steps below:
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap Apps > Settings > Backup & reset > Factory data reset > Reset phone.
  2. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  3. Tap Erase everything.
Master reset with hardware keys
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card. If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
  3. Press the Volume down button to highlight wipe data/factory reset.
  4. Press the Power button to select.
  5. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  6. Press the Power button to select.
  7. Wait as the device resets.
Hope this helps!
Device resets ZTE ZMAX
Nov 01, 2017 | ZTE Cell Phones
Reset zte maxx
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to the 'PERSONAL' heading, then tap Backup & reset.
  4. Tap Factory data reset.
  5. Tap Reset phone.
  6. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  7. Tap Erase everything.
  3. Press the Power button to select.
  4. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  5. Press the Power button to select.
  6. Wait as the device resets.
Nov 28, 2016 | Tablets & eReaders
Return Sharp XE-A102 cash register to factory settings
MASTER RESET
Master reset: Clears all the memory and initializes each preset parameter. The master reset should be performed by using the following procedure.
1. Turn off the power (Power OFF). (See Note 1.)
2. Remove the memory back up battery from ECR.
3. Turn the mode switch to any position other than Power OFF.
4. Turn on the power (Power ON). (See Note 2.) When the master rest is completed, the buzzer sounds three times.
5. Install the memory back up batteries back into the ECR. The master reset can also be accomplished in the following case. (See Note 3.)
Note 1) Power OFF: Means disconnecting the AC power supply to the machine. (Specifically, unplugging the machine.)
Note 2) Power ON: Means connecting the AC power to the machine. (Specifically, plugging in the machine.)
Note 3) In case a power failure occurs when the machine has no battery installed, the master reset operation is automatically performed after the power has been restored.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 05, 2016 | Sharp XE-A102 Cash Register
What is a master reset
A master reset is a reset to the factory settings that was originally on your device. For instructions on resetting your iPod to factory settings, click here:
Restoring iPod to factory settings
Aug 11, 2014 | Apple iPad Tablets & eReaders
Securety code eror
check this one
Master Code Generator will Instantly generate your Nokia's Master security code.
This service can be used if you need to reset your Security Code.
Your IMEI: 356924034968264 --
Your Nokia Master Code: 2401254345
or this one
Nokia 5000 hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
Apr 21, 2014 | Nokia 5000 Cellular Phone
How can i reformat my motorola cingular v3xx?
The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to "Settings"
2. Next go to the selection for "Initial Setup"
3. Next go to the selection for "Master Clear"
4. Then select to confirm the option.
5. Now enter the security code which should be "000000"
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a "hard reset", "hard reboot", or "master reset" on your Motorola V3 RAZR and it should return to normal operating mode!
May 01, 2011 | Cell Phones
To restore the factory setting
how to restor k300i factory settings
Mar 10, 2011 | Cell Phones
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
5. Now enter the security code which should be “000000”
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
I have a motorolla ming... i dont know the code for the master reset / master clear / its asking for a 6 digit code / i do see only in the manual a 4 digit code
You have the option of using Master Reset or Master Clear to reset settings, and remove information.
Master Reset resets all settings on device to factory default.
Master Clear resets all settings to factory default, plus clears all data from the device including: PIM data, Call History, Settings, etc.
To perform a Master Reset or Master Clear:
  1. Press Start.
  2. Scroll to and select System Tools.
  3. Scroll to and select either Master Reset or Master Clear.
  4. Press Yes when Alert appears.
  5. Enter Master Code (normally 000000).
Feb 19, 2009 | Motorola Mobility RAZR V3
Xerox WorkCentre 432 ST Copier Logo
1,047 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
