Question about Canon imageRUNNER 2020 All-In-One Laser Printer
Unable to print to canon IR 2020 when connected through router.
I connected the IR 2020 to the router via the rj45 and the indicater light on the router shows that the printer is connected to the port but I am unable to view or connect to the printer from any of the computers on the network.
Prob not a privalges problem unless you are using a DC more like a firewall problem try reboting the router
Posted on Oct 04, 2012
  • 1,219 Answers
Try to conect directly with cross utp cable to an pc, if every thing works, its your network problem (maybe privilegies, banns,...) if not ... good luck :-)
Try to reconect the pcb s
Posted on Mar 02, 2010
  • 26 Answers
Ok. on canon products there will be a network port but does not mean its a network printer, iR2020 is copier only and iR2020i will be network printer i version will be network ready, non i version would not, but can be by purchasing the bootrom to be installed to enable the network function. or you can use the USB function to one pc or usb hub to multiple pc's
Posted on Aug 05, 2013
How to share printer with two computer on IR 2020?
Does the ir 2020 have ethernet
The easy way is to share the printer out on one of the p.cs and then add the printer on the other pc. Draw back is Sharing P.C has to be switched on all the time for other p.c to print.
I know how hard it is to get after market support for photo copiers. You may be able to use a USB print server and then plug it into a Ethernet hub or Switch and set up the IP addresses on the two p.c's and the Print server.
Jan 29, 2015 | Canon Office Equipment & Supplies
Ir-2020 is network option connect a network card and a switch connect all computer and ir-2020 to the switch. Configure the system.
Jan 29, 2015 | Office Equipment & Supplies
Default password for canon ir 2020?
  1. Enter the IP Address of the printer into a web browser.
  2. Enter the System ID. The default ID is 7654321.
  3. Enter the password. The default password is 7654321.
Jul 23, 2014 | Canon iR 2020i Laser Printer
I have some problem with canon ir 2020 copier i can't change language.
depending on the region you can change the language via internal programming, other wise you have to purchace an Ic that controls the language sequence under the display
Feb 05, 2013 | Office Equipment & Supplies
Download standby error for Canon iR 2020
flashing the machine to the latest system sst and firmware.
Jan 22, 2013 | Canon iR 2020i Laser Printer
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
Canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Jun 16, 2009 | Canon iR 2022 Printer
Router with RJ45 cable port available
Nowadays most routers come with RJ45 connectors. That is a connector for network cable.
You might be talking about a serial port, found on many security systems.
If you want to connect the security system, you need a serial cable to connect the security system with your computer, and thru a specialized software (more certain provided by the security equipment, be able to perform the task you have in mind.
If this answer helps please don't forget to rate it
Jun 14, 2009 | 3Com Router Cable E1 1200HM RJ45 20M...
Canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
Nov 14, 2008 | Canon ImageRunner 2016 Copier
Canon imageRUNNER 2020 All-In-One Laser Printer Logo
623 people viewed this question
old marine
old marine
