Question about Frigidaire FDG546RE Dryer
Dryer is not heating up.
How do I know if the machine is getting gas or just malfunctioning?
I don't know if this will help or not but have you tried cleaning the vent tube and the vent inside and out? Also if you use dryer sheets the lint screen probably needs cleaning. To do this just wash it in some hot soapy water and rinse. You will be surprised that all this will help. Good luck
Posted on Dec 10, 2008
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: roper gas dryer does not
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 28, 2010
Describe your Dryers Problem kenmore series 700 gas dryer wont heat there seem to be something keeping the lint screen from going all the way back into place but I cant reach it or vacuum it out and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101---=\
Aug 31, 2011 | Dryers
Will not dry cloths
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Feb 21, 2011 | Maytag MDE7600AY Electric Dryer
Roper gas dryer does not heat, timer does not move, runs continuously, can the timer malfunction cause dryer not to heat?
heatman101
Oct 22, 2010 | Roper Dryers
Gas dryer starts out ok. When it needs more temp to keep drying, the glow plug turns on and waits for the lp gas to show up and nothing happens. My quess, 1. solenoid valve malfunctions 2. no flame...
heatman101
Sep 03, 2010 | Amana NDG5800 Gas Dryer
My LG tromm dryer wont heat and i don't know how ignite the pilot
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Gas dryer not heating all the time
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 27, 2010 | Whirlpool LGR5636PQ Gas Dryer
Kenmore series 80 gas dryer will not heat up
Hi. this dryer has a set of coils that sit on top of the actual gas valve assembly. these coils activate the main and secondary gas valves and if the coil assembly is malfunctioning or, the wires and clips are corroded, the coils will not activate the gas valves to open and close. this malfunction will affect the heating process within this dryer unit.
I recommend inspecting the dryer coil assembly. use a mulitimeter to test for Resistance. you should get a reading of some type of current flow through the wires and, if this is the case, the coils are bad and they will need to be replaced.
This test is actually not needed. the non existing heat is a red flag on its own and, it greatly confirms a major failure within the coil assembly. replacing the coils will fix your dryer.
PLease rate and god bless:)
Apr 20, 2009 | Kenmore Dryers
No heat in dryer
make sure the gas is on to the machine and then make sure gas is getting to the machine and then if still not heating check ignitor
Apr 14, 2009 | Maytag SDG3606A Gas Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
