Question about Acer TravelMate 2300 Notebook
WRONG VAULTAGE ON ADAPTER
I WAS VERY SILLY AND PUT THE WRONG VOULTAGE ON MY LAPTOP I PLUGGED IT IN AT 24V INSTEAD OF 19V AND NOW IT WILL NOT WORK AT ALL . SOMEONE SAID THE BOARDS ARE BURNT OUT AND IT IS NOW WORTHLESS AQM I BEING RIPPED OFF.
  • 117 Answers
Only solution is go to acer service center they can test is MB really burnt out, if so, then its bretty expencive to buy new.
Posted on Dec 10, 2008
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
Specs:
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
What happened to my Bose Soundlink? what to do?
You probably fried your Soundlink by using the wrong adapters. In general, an adapter yields the rated output at the rated current so connecting a 19V, 3A adapter instead of a 19V, 1A adapter applied much higher voltage.
Mar 10, 2017 | Bose Soundlink Wirless Mobile Speaker...
Will Universal AC Adapter 15V 16V 18V 18 5V 19V 19 5V 20V 22V 24V 70W work for BMS 10H product
I suggest that you use the ac adapter intended for the model of your computer to avoid from getting any problems.
David
May 26, 2013 | Computers & Internet
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
My 500gb iomega external hd model : MDHD-UP . is not working i think its the power supply that has a problem because my friend use the wrong adapter instead of the right one 12v he use my laptop's
Hi sir/madam
Use only 12v adapter for your drive...purchase same volt adapter...
Still not working remove the casing of iomega , connect it as internal drive on desktop ..
If it is under warranty pls go for service centre
Sep 21, 2017 | Computers & Internet
Fujitsu lifebook blinking battery led, bad ac adapter?
i would try purchasing a universal laptop charger on ebay and see if it works. they are under 25 bux. worse case scenario you will have a backup ac adapter. be careful plugging in other ac adapters because the polarity could be wrong or it could have to much amps
Jul 11, 2010 | Fujitsu LifeBook A6025 Notebook
Mistakenly plugged maxtor one touch 2 into wrong power adapter
Well Most Likely The Circuit Board Burnet Out Since Its 12V And When Plugged Into A 19V Supply It Will Burn Out Instantly Because It Over Charges The Circuits. So Its Not Possible To Repair Such Damage But You Can Take Out The Hard Drive And Plug IT Into A Desktop Computer And Use It At Home Or As An Online Hard Drive To Store Files
Jun 18, 2009 | Maxtor 160GB OneTouch III Mini USB 2.0...
Acer aspire 5610 plugged in with incorrect ac power adapter
Probably is fried- Your probably looking at around $200 for a refurb motherboard and then whatever your local tech place charges to install it. :( probably not what you wanted to hear- sorry
Apr 08, 2009 | Acer Aspire 5610 Notebook
Wrong Power Adapter
Yes.If the voltage range exceeds the limit,"astalavista baby."
If the voltage is was below recommended,try plugging in Power Only,turn on,leave for a minutes.This should adjust the voltage regulator back to normal.
Feb 04, 2008 | Western Digital 320GB MyBook Premium Ext...
Laptop adaptor problem
Yes should be no problem if the plug will fit in the laptop. Probably won't charge the battery but seeing as it is putting out less amps I can't see it hurting anything. Have used an adaptor like that on my IBM for some time now. Calls for 4.5 amps but I only have an adaptor that puts out 3.8. Works fine just have to turn it off to charge the battery.
Dec 11, 2007 | Televison & Video
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
