Question about ASUS P4XP-X Motherboard
Failure in boot up after updating p4xp-x
I upgraded the bios in windows environmet by asus utility, upgrade from 1003 to 1004 version, in finalizing procedure in level 3 the problems noted an error , after restarting :the monitor indicator show standby mode ,and nothing can be seen, even post screen, after using motherboard CD and leave pc for along time i try again and nothing was appeard, after a day i turn it on and system boot normally without any problem but ,unfortunetly that day i try again" the upgrading procedure" but after this until now after nearly 80 days i cant recover bios to its initial condition,how can i recover it ? i want to save my money by recover it and without pay for another motherboard
    Novelist:
  • 152 Answers
Typicaly, i would say " if it isn't broken don't fix it!"
A bad bios flash can " brick " your computer, meaning unless you know someone that can write directly to the bios chip to fix the bad bios flash, the motherboad is as useful as a brick.
As for attempting to fix the problem... If the system is still under warranty, request an RMA from the manufacturer. If not, try the following:
On your motherboard, near either the bios chip, or the CMOS battery, there is usually a dip switch or a jumper. It will almost always be labled.. if not, check the motherboard documentation.
WARNING: DO NOT CLEAR THE CMOS WHILE THE SYSTEM IS POWERED!
Set the CMOS reset / Clear jumper to the alternate position, wait 10 seconds, then set it back to the normal position.
Attempt to boot the PC, if you still fail to boot, you may need to have someone flash the chip onboard, or get a new motherboard.
For future reference, i see alot of motherboards DOA because of bad flashes. If the system works, don't flash the bios, only flash the bios as a last ditch effort to fix a problem. NEVER, i repeat NEVER flash the bios from within the operating system. It's a terrible idea, there are too many other applications running that could cause a system halt or problem with memory that can cause the bios flash to go south.
Posted on May 29, 2009
    President:
  • 2,351 Answers
Hi rouzbeh_be20, you can try clearing the bios jumper & removing the cmos battery. (Do not forget to re-set the bios jumper back to normal).
Check the battery for 3 volts DC. If the battery is less than 3 volts DC replace the battery. You can call Asus & ask for a replacement bios chip. Your board was made back in 2003 but Asus can flash a bios for you. The last time I ordered a bios from Asus it cost me $5.00 US not including shipping. You can call Asus California M-F 8:00AM. to 5:00PM. PST. At ( 510-739-3777 ). Only the CA site can order a bios for you.
Tech support live chat; http://livesupport.asus.com/
Write down the SN# found on the pink parallel port (In side the case). Asus will want that information.
Having the bios chip replaced is the cheapest way around this issue.
Good luck rouzbeh_be20!
Thank you for using fixya.
Mike
Posted on Dec 11, 2008
2 Suggested Answers
Dipu007
  • 2110 Answers
SOURCE: boot failure after upgrading bios asus p4xp-x
You have accidently corrupt mother board BIOS,you have to replace it ...no other choice...
Posted on Dec 10, 2008
I want bios update my IBM Lenovo 7298 pc
Hi
If you go to the page below there are many options for installing a BIOS update.
Desktops and all in ones ThinkCentre Series desktops ThinkCentre M58e...
There are also various utilities to help you upgrade the BIOS, including one for upgrading from within Windows. You should make sure that you have a full backup of your data and programmes before you start. Please make sure that the version here is an upgrade compared with your current version and that you read the instructions very carefully and are comfortable with them as incorrectly upgrading, or interrupting the upgrade can lead to your machine refusing to boot at all from anything. Please be careful.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 16, 2015 | Lenovo ThinkCentre M58e 7298 Core Duo...
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
How do i upgrade bios
Hello download the bios version here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5AD2-E%20Premium&p=1&s=22
By selecting your windows system.
Open bios folder, and click global for download, for the newest bios version.
Download also ASUS Update, In utility, and please unzip both files.
Install first asus update, and run the program, select update bios from file, and select the bios version you have downloaded, the rom or bin file, and click next.
Now the bios update process will begin.
DO NOT turn off the power, when the process is running, and you have to setup the whole bios, when the job is done.
Follow the instuctions on screen, when you have rebooted.
Good luck
Mar 02, 2013 | ASUS P5AD2-E Premium Motherboard
What are the instructions for flashing BIOS?
Hello use auto detect here to find the right mainboard:
http://support.asus.com/download/options.aspx?SLanguage=en
Download asus update, this is the easyest program to upgrade the bios, while windows is running.
Install first asus update:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
When the mainboard is found, select download, and select your windows system.
Open the bios folder, and download the latest bios version.
Unzip the bios file.
Run asus update, and select update bios from file, and select the bios file, in the folder you just have downloaded ( the bin file )
Be very carefull when you upgrade the bios, because a power loss will damage the mainboard, while the upgrade process is running.
You also have to setup the bios settings, when the job is done.
You have to select F1 or F2 to enter the settings.
If any doubt download the manual.
Good luck
Feb 07, 2013 | ASUS Computers & Internet
I need m2n68-am bios bin file
Hello download here at asus:
http://www.asus.com/support/Search-Result/?keyword=m2n68-am
Select download and your windows system.
Open the bios file folder.
Click on global for download.
Unzip the file.
Make also sure it`s the right mainboard, because flashing the bios with a wrong one, WILL destroy the mainboard.
Use the asus update utility, to upgrade the bios, while windows is running, for a safe upgrade.
Good luck
Jan 15, 2013 | ASUS Computers & Internet
I cannot install windows 7 on my p5vdc-mx motherboard, it keeps freezing on installation
Uodate the P5VDC-MX BIOS to version 0806. Download it from ASUS official site.
Aug 03, 2010 | ASUS P5VDC-MX Motherboard
Boot failure after upgrading bios asus p4xp-x
Dec 10, 2008 | ASUS P4XP-X Motherboard
Motherboard BIOS softwere for update
The process of upgrading the BIOS on a computer is also
called "FLASHING" the BIOS.
On very old computers (486 and older) the BIOS may be
permanently programmed into read-only memory chips,
which are not flash-able, although it may be possible to
replace the chips, or re-program them using special
equipment by a qualified technician.
On virtual all modern computers, the BIOS can be updated
using new data and a special FLASH program available via
download from the manufacturer.
This is a very dangerous procedure that can destroy the
motherboard if performed incorrectly, and should not be
performed unless absolutely necessary, such as when
you computer or software will not run properly without it.
Most mother board manufacturer's (for example Asus) offer
software patches and downloads on their web site, as well
as BIOS upgrades.
Note that the BIOS is 100% board specific, installing the wrong
BIOS can permanently destroy *********** board, so make sure
that you download the correct one for your board.
Once you have the downloaded the BIOS upgrade, there are 3
possibilities:
1) The downloaded file is self-installing, either from Windows,
or it creates a boot-able diskette, which in turn contains all
the files needed to update (FLASH) the BIOS.
2) The BIOS comes with a a separate installer (.exe) which
either runs from Windows or via a boot-able diskette.
3) The existing BIOS has a "built-in" flash utility, accessable
through the BIOS settings. This utility runs at a very low
level without any operating system to self-update the BIOS
from your download binary file, located on the hard drive or
on a diskette.
This is by far the best and safest way to do the job, but only
if your motherboard and (existing BIOS) has that capability.
In any event, the first step is to visit the manufacturer's WEB
site, then go to SUPPORT or DOWNLOADS.
Find the exact model and version number of you motherboard
in the manufacturer's list, and download the latest BIOS
update, and any installation (or flashing) utilities that come
with it.
1) Follow the manufacturer's instruction exactly !!!!
2) Do not turn off the computer until the BIOS update is
complete, and you are instructed to do so !!!
N.B.
The computer BIOS is the lowest level program on your PC,
without which the computer CANNOT read the disk drives or
perform the lowest necessary functions.
If the BIOS is damaged, or
If the wrong upgrade is installed, or
If the upgrade is performed incorrectly, or
If the upgrade is interrupted or crashes before finishing,
the computer may become unable to repair itself, and
the mother-board may become permanently unusable.
(This depends on the actual mother-board and BIOS design,
and on the damage done by the failed installation)
Good luck,
Please rate my answers,
Martin
Aug 04, 2008 | ASUS P5L-MX Motherboard
BIOS 1004 cpu not support
I got it :-)
Damn Asus , it was a hard session ;-)
1. Make an ISO from your original Asus CD denn insert (with isobuster or something) the Bios Firmware 1004 in the main Dir name the file M2N-MX.ROM
2.Burn a Second disc with the 0804 Bios ROM also rename the 0804 Rom to M2N-MX.ROM
3. Go to EZ FLASH with ALT + F2 and then insert the 1004 CD wait till Erasing is ready Then Turn OFF your PC :-) so you crashed the bios thats what you need to run the embeded CrashFRee Tool
4 After you turn your PC on insert the 0804 CD then it flashes the this Rom and we are Happy :-)
mfg Eddi Hope this helps someone
Apr 16, 2008 | ASUS M2N-MX Motherboard
ASUS P4XP-X Motherboard Logo
323 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
