Question about Epson Stylus Pro 9800 InkJet Printer
Sensor error in the Epson stylus pro 9800
For some reason my 9800 is having a paper sensor problem. Example: I send a job which I want 8 copies of (this is on a 36" wide roll) . It prints the first one and cuts it (I have it set to cut) Then it pulls down the pap,er sensors it, rolls out about 5" cuts it, it then re-sensors the paper and put up a sensor error on the LED even thought the paper is exactly where it belongs. If I flip open the paper lever and then close it then starts printing..until the next copy is ready and then I start the whole process all over again over again grrrr. Also if I try to do an auto head check ( through the menu on the printer or the print utlity) it does the same thing except that after it cuts off 5" and then re-sensors it and I open and close the paper lever to clear it, it never prints the pattern.
  • 16 Answers
Sounds like you need a new sensor. call tech support
Posted on Jul 12, 2009
Computer says paper jam in printer but printer will make copies
Welcome to the ever popular-widely experienced world of:
YES! That wonderful world where unbeknownst to you but knownst to us (OK I watch Spaceballs WAY TOO MUCH) When you are sending a print job, somehow the paper size setting has been changed. Either in the printer itself, or in the print properties settings in your OS.
Double-check those paper size settings and try to print. If it still happens, try resetting the print settings in the printer back to factory default. Make sure you print out the printer configuration before resetting in case you need to reinstall those settings.
Nov 06, 2013 | HP PSC 1401 All-In-One Printer
Epson 4880 incorrect paper source setting
you have to chose sheet paper before sendding the print command.
Apr 02, 2013 | Epson Stylus Pro 9800 InkJet Printer
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Can't perform a nozzle check - Sensor error load different paper
Hi tom_kolasa,
Here is the manual for your printer model. Epson Stylus Pro 9800 Printer Guide
Hope that the manual contains everything you need from nozzle check to sensor errors.
Apr 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
E3 on LED paperwill not feed
What you want to do is remove all paper, the prepare to run a print test page or print a blank sheet from some program, any program. Just be ready to do this.
Now, find a magazine cover or index card stock, something firm. Cut this magazine cover to the same width as regular paper 8 1/2 in the US or A4 in Eurpoe.
Now, when you start the print job, push the magazine cover or index stock through while its printing. Apply pressure it the key, to getting the thicker paper through.
This will clear the sensors in the printer and remove the error message.
Why did this happen? In the printer, there are numerous sensors to identify jammed paper. This can happen for the strangest reasons. By pushing thicker paper through while feeding paper by running a print job, the thicker paper forces the sensors back to their original position.
Nov 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper Jam
I have this problems whit Cleanout Assembly you need change it and problem solved cleanot assy have paper jam sensors and if sensor damaged you have problem whit paper jam !!
Aug 01, 2008 | HP Designjet 110plus nr InkJet Printer
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson 9800
Low Paper message on the LCD means that the media counter has been turned on and it is now at a point where the printer thinks that there is not enough paper to run a job. Here is what you need to do:
1) Turn the printer off
2) While holding the Pause Button turn the printer back on
3) Scroll down to Paper Count
4) Hit Menu to select
5) Scroll up to off
6) Hit menu again and a star will appear indicating that the Paper Count is off
7) Power down the Printer and then Power it back up
This should take care of it. If you have any other issues, feel free to contact me directly.
Sean McGettigan
LexJet -
Feb 27, 2008 | Epson Stylus Pro 9800 InkJet Printer
Borderless error with 44' paper
Are you setting up a custom paper size each time? Check out page 91 of the 9800's user manual... it has a table of recommended custom paper widths for borderless printing.
Feb 23, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson Stylus Pro 9800 InkJet Printer Logo
525 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
