Question about Tripp Lite HT1000LCD UPS System with LCD Display UPS System
I have trip lite model HT1000LCD.
The unit completely shut down and I restarted it by pressing and holding down the power button for a few seconds. Now the fault light is on and the unit emits an occasional beep. I have had the unit for 2 1/2 years. Is it at the end of its life or is there something I can do to correct this problem.
Thanks,
Lane
4 Suggested Answers
jvpacoin
  • 91 Answers
SOURCE: Tripp Lite SU2200 UPS has faults
For Tripplite UPS basically if the fault indicator is on you already have to check the power mosfets/IGBT on the circuit board. if you know the basic of UPS you dont need all those schematic diagram to check the thing. by the way, try to check your battery first if its still working. and if the battery is ok, go and check your inverter
Posted on Jun 04, 2009
  • 84 Answers
SOURCE: Smart2200RMXL2U shows no sign of life after storage
These units, while hot swappable, will NOT start with dead batteries connected.
You will have to replace the batteries to confirm if the unit is still usable. Sealed Lead Acid Batteries do have a shelf life when a charge is not applied and will fail after several months of sitting around.
If your unit was working fine before it was put in storage, I definitely would consider just replacing the batteries. It is possible that the batteries are connected loosely, you can try opening the unit up to double check all the connections but if it has been sitting for more than a couple months, I would definitely consider the batteries dead.
You can find replacement batteries here http://www.refurbups.com/Tripplite-SMART2200RMXL2U-Batteries
Posted on Apr 05, 2010
Testimonial: "Thanks Phil! Good to know it won't even try to charge a dead pack. Before buying new batts, I'm going to put 48VDC to the Anderson connector."
  • 3 Answers
SOURCE: Tripp Lite OMNI 1000 LCD will not stay on
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Posted on Oct 19, 2010
epettingill
  • 175 Answers
SOURCE: Tripp-Lite #HT1000LCD. I have had
Your batteries would have been weak from 5 years of use. The Lightening could of blew out one of your batteries. The UPS did it's job but at a price. I would replace the batteries first then see how it works
Posted on Sep 12, 2011
How do I turn off "safe mode" on a Samsung Galaxy S4?
To turn off
Powering down , then back on should do the trick. Be sure to completely down. Do not select "restart". If you still have problems, remove back cover and pull battery from device. Leave the battery out for about 60 seconds, then place the battery back in, assemble the rear cover and start the phone again.
Some galaxy s4 models may require you to press and hold the volume down button during start-up in the same manner as enabling it to exit safe mode.
http://www.technipages.com/samsung-galaxy-s4-turn-safe-mode
Nov 17, 2015 | Samsung GALAXY S4
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
I have a Tripp-lite UPS HT1000LCD and it shows 120 charge but unit will shutdown and restart intermittently.
I had the same problem with the same model. Here is how to fix it:
Recycle the battery (you need an absurd screwdriver to get to it), throw away the unit, and buy an APC ups, which is not only reliable, but has user replaceable batteries.
Sep 08, 2012 | Tripp Lite Computers & Internet
Need recovery disc for Toshiba A105.
Instructions1 Click "Start" then "Turn off" or "Shut down" and click the prompt to shut your computer off completely. Let the computer remain off for a few seconds.
2 Hold down the "0" (zero) key on your keyboard and press the power button.
3 Release the power button but hold the "0" until the system restore screen loads.
4 Select "Restore the original factory image" by pressing "1" on your keyboard. In some models, you may be able to click the appropriate restore setting. Press "Yes" or "Next" to continue.
5 Restart the computer when the recovery is complete by pressing any key. The computer will let you know when it is safe to do so.
Thanks
Apr 02, 2012 | Toshiba Computers & Internet
Remove the power plug. Hold the RED X button for few seconds.
"Remove the power plug. Hold the RED X button for few seconds" by doing this procedure, unit will shut down but if you got a bad external battery it will shut down right after you unplug the power or will not shut down completely. If you still need help call (775)358-2922 ask for Randy. Thanks
Nov 12, 2011 | VeriFone VX 610 Credit Card Terminal...
I want to restart of shut down my HP iPAQ rx3115
For the HP iPAQ rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Mar 01, 2011 | Cell Phones
Shut down in sleepmode by mistake, how to awaken?
Press enter twice or press power button to awake.
Thanks,
satheesh
Jan 20, 2011 | Computers & Internet
We have a new Acer Aspire one and the mouse is frozen. When I try to turn off the unit nothing happens. How do I free the unit or turn off everything?
As this was posted a month ago, I'm presuming you've solved the problem?
However, when your laptop locks up completely, the mouse won't move and the keyboard is unresponsive (press the caps lock key and see if the caps lock LED comes on or off?)
Press and HOLD the power button for a few seconds until the laptop powers off, Wait a few seconds and then power it on again, the computer may moan that it wasn't shut down correctly, but this is normal (because you couldn't shut down correctly)
Jan 15, 2011 | Acer Aspire One A150-1006 Notebook
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
How to turn off TomTom gps one 130
Gps 130 is supposed to hybernate only. It is almost impossible to turn it completely off.
Nov 12, 2009 | Tomtom ONE 130 GPS Receiver
Computers & Internet Logo
254 people viewed this question
Top Tripp Lite Computers & Internet Experts
Joseph Hoffmann
Brian Sullivan
Brian Sullivan
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
