I have a mac book and it doesn't charge there is an x on the batt
The charger only works when I have it plugged in but It doesn't charge
    Scholar:
  • 56 Answers
Hi im blulite and your problem i hink is that your battery is not charging anymore, if its new have it change it should be still under warranty..
Posted on Dec 10, 2008
Cruz tablet
The charging light should remain on as long as the charger is plugged in and charging I suggest you try to troubkeshoot your charger as it might be faulty.
Sep 23, 2013 | Velocity Micro Cruz T410 4GB 10"...
Hi i have an HP Elite Book 6230p,my laptop stop charging recently, i was charging it and i removed my charger plugged in another charger of lower current rating it worked well for a while, but when i...
Nice books, have many. 8540s./. better.
i can not decode this post.
sorry
does it run with no battery and the correct pack
mine has 10 options new the i7 and the fast video card suck huge power and mine needs a 100watt pack, the 65w on mine is HOPELESS. see?
run the correct matching pack,
step 2 a new battery, i keep 2 good ones all the time
on Vacation, id not be wanting to find batteries 3000 south of here, ever. (south of the boarder)
test with no battery
then with correct power pack (the charger is a chip inside the pc and in this 19vdc pack its only a power pack pure DC.
then try a new battery ,
if you read your service manual at HP.com
it tells you all packs used and why, and the match.
sure does.
and varies by OPTIONS DAY1. in all case
unless upgraded like mine, is, and sucks max amps mine does.
Jul 03, 2017 | HP EliteBook 6930p Notebook PC
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
My cell get heated when i put charge batt chg circuit of cell isnot functioning i get batt chg from universal charger nokia1100
Usually it is the battery hat is becoming old enough to internally short and this will cause it to work poorly and not ever fully charge, and get warmer than normal or hot when attempting to charge for more than 1/2 hour. Sometimes the chargr can go bad and over charge, thus making the battery too warm. if you have a car cell phone charger that plugs into cigarette lighter outlet , you can atach this and see if battery gets too warm, but these chargers usually charge faster than electric plug-in type, so expect some warmth within 20 minutes, but again if too warm than you know itis the battery. For these unnits batteries are not expensive.
Apr 28, 2010 | Nokia 1100
Won't turn on
Did you try to disconnect the battery and connect you mac book to the charger? If it turns on with the power connected and without the battery, probably your battery is broken.
May 04, 2009 | Apple MacBook Mac Notebook
Plugged in, not charging inspiron 1521
This is a known issue with the AC adapter. If you are under warranty Dell would replace the AC adapter which will fix the issue. If not you may need to purchase one. Also do make sure you have the latest BIOS update on the laptop.
Latest BIOS
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R178138&SystemID=INS_PNT_PM_1521&servicetag=&os=WLH&osl=en&deviceid=13136&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=242484
Before updating the BIOS make sure you unplug all the USB devices and restart the computer once, and only then start the BIOS update.
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 05, 2009 | Dell Inspiron 1521 Laptop
No power, all buttons flash when connected to ac charger
if charger voltage is ok then it could be phones charging controler is not working. if phonebook is only thing you need could recharge battery directly from your charger and then save your phone book. cut off charging plug-connector from your charger make two bare wires and then apply red wire to battery "+" and blck to "-". 5min of charging will be enough to copy your data
Jul 21, 2008 | Samsung SGH-c225
No charge
check the batt mayb your batt drained off... try using other batt.  if still doesnt work, probably you have a software or hardware failure...
but if it works w/ other batt try charging it, if still doesnt charge your phone charging section have a prob...
just visit your nearest service center to help you...
Oct 26, 2007 | T-Mobile SidekickĀ® 3 Cellular Phone
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
