Question about RCA Televison & Video
I have hooked up the cables as per instructions,icannot record to my vcr . do you think you can help?
    Genius:
  • 1,199 Answers
Cable box.. to vcr... vcr to tv!...make sure your vcr is monitering the channel you want to record!
Posted on Dec 10, 2008
Looking for user manual for philips magnavox tv. 9P6044 C104, 3911Q1716. Trying to find out how to hook up my VCR to this tv. It has s viedo, video, L audio & R audio holes on front side of tv. I want...
Barb..be sure you run a TV signal through the VCR first. And then a coaxial from the VCR to the TV. This is the easiest solution for now. And set the vcr to tv/video {channel your movie is on}hit record and hit tv/video and watch your tv for another movie!
Feb 06, 2010 | Philips 9P6044C 60" Rear Projection...
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
I have a Sony SLV-SE 710B VCR and a Sony Bravia HD TV I now wish to record my videos (about a 100) onto DVD. What Sony DVD recorder will take the output from this VCR and put it onto disc or do I have to...
You need to buy Sony DVD Recorder and hook Sony VCR to that dvd recorder and burn DVD directly. You can also watch VCR tape movie on TV via dvd recorder while its being burn on dvd.
Click Sony Style to select DVD recorder.
May 11, 2009 | Televison & Video
How do L set up the converter with a TV , a vcr and "Dish" satte
It sounds like you need a three way splitter.
You need to reverse the connections; the splitter has input and out. Hook exterior antenna, converter box, and satellite to the three side terminals (out). Hook the single sided terminal to VCR input. Connect the VCR out to the TV input. This configuration assumes that you will be using the VCR to record from all inputs. The TV has to be set to channel 3 to act as a monitor for your other devices.
Hope this solves your dilemma.
Feb 22, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I cannot record a show onto a blank vhs tape in my vcr??
Initially, pls verify that the coaxial cable is connected to the ANT/Cable/RF IN of the VCR. Thereafter the built-in tuner of the VCR would be used to select the desired channel to be recorded. The VCR in turn maybe connected two (2) ways to the TV:
  • Audio/Video using yellow, red & white RCA cables/connectors using AV1 or Video1;
  • RF patch cord from RF OUT of VCR to ANT/Cable/RF IN of TV using either Channels 3 or 4.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Televison & Video
Can't tape tv program on VCR while watching another show on digital cable.
If you set it up right per Comcast instructions:
Your VCR will record a show off of its built in tuner while you are watching another show from the cable box.
Make sure that the AB switch is set into the correct position and that you are only recording a show that that isn't digital. I believe you can only record shows up to channel 150 off the VCR tuner. Anything higher than that won't work.
If your Comcast Cable Tuner has two AV outputs in the back of it, you can skip the AB switch altogether and plug the one of the cable tuner output lines into the back of the VCR input lines. That way it can record that show you are watching on the cable tuner at that same time.
Jul 19, 2008 | Televison & Video
Digital to analog converter box to tv/vcr combo
You will need a splitter and an rf modulator to do timed recording of programs. The instructions are on the dtv answers website, option # 2, record and watch a different channel. The recording is for the analog stations 1-24. You cannot record the higher stations. The items I purchased were a 3 way splitter $7 at local hardware store, an rf modulator $25 at Radio Shack. The other option was to get a cable box for the tv and record off of that at $6.95 a month or a DVR for $8.99 per month, all from comcast. The price that I paid for the items I needed would be repaid in 3 months if I were to go the comcast route. The conversion is nothing more than a money making scheme for them.
Mar 21, 2008 | Televison & Video
VCR
Have not heard back. Make sure your connections are correct per users' manuals.
Mar 07, 2008 | Televison & Video
Connecting VCR/DVD combo
Confusing! TV with NO yellow,red white input ? Buy an RF
adapter Radio Shack about 30.00.....TV has input ? = yellow
video,audio R,L from Insignia source dvd/vcr out ( audio R,L,
video {yellow} ) You don't need to switch cables.As to record
feature,consult owners manual..................................T
Nov 21, 2007 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
