Question about Korg Pa800 Synthesizer
Korg pa 800, SMF and Harmonizer
I am the new owner of the Korg pa 800
I mostly perform live using SMF (standard midi files)bought on different professional online SMF sites. Most of them do not have a track for the harmonizer.
How do I make the harmonizer work with such kind of SMF?
Do I have to create an harmonizer track?
If so, how do I do it and what are the necessary steps to create it and set up the keyboard in a way that when I load each SMF the harmonizer is automatically ready to work?
thank you for your prompt response
MARCO MISSINATO
    Sergeant:
  • 399 Answers
U will need the software supported by your device to do so.
Posted on Dec 10, 2008
  • 19,396 Answers
You need to edit the midis on a computer with a specific software and add a track for the harmonizer , I think you can also add a track with the korg.
  • Ginko
    Ginko Dec 10, 2008
    The solution is quite complicate, the possible solution to add a track to the MIDIs on a computer will work, but the thing to do is another.
    You must select a track in the SMF and use it with the the harmonizer.
    If your MIDI for example does not have piano track, you assign assign on the specific SMF the bass track or the melody.
    Apparently this is more complicate on a Korg than on other similar keyboards. I do not have PA 800 user manual to tell you the the exact steps.
    See the link below, there is a discussion on this problem.
    See here: Korg Pa 800 - Harmonizer and SMF - Synth Zone BBS
How to convert midi files into smf data files for casio 810in?
i found this for you
SMF Converter is software that converts commercially available Standard MIDI file (SMF) data to a format that is supported by CASIO electronic musical instruments, and then transfers the converted data to the instrument. After data is transferred, it can be used with the lesson function for lesson play. For details about using converted data, see the user documentation that comes with each instrument. http://music.casio.com/e/smf click the blue download button near bottom of page.---- not the four other links.
Jul 25, 2016 | Casio Music
How to reset pa 50
The manual should the factory re-initialization procedure. If not contact Korg customer support
Dec 10, 2014 | Korg Pa50 Professional Arranger Keyboard...
HOW TOGET NEW TONES IN SDCARD
You can't use SDCARD for CTK810 model.
Please connect to a computer using a USB cable. Then you can use a commercial MIDI file player to play to your keyboard.
Alternatively, you can download SMF Converter from
http://music.casio.com/e/smf/
This program will convert SMF (.mid files) into a format readable by your Casio keyboard and then load it directly into your keyboard.
May 03, 2014 | Casio CTK810 61 Key Keyboard
Ctk 810in not able to read or play midi files
If you connect to PC using USB interface, then use a commercial midi player - e.g Melody Assistant or Harmony assistant to play MIDI files to it.
Or else download "SMF convertor" to convert midi files and download compatible file to keyboard.
Aug 10, 2013 | Casio CTK810 61 Key Keyboard
How do you hookup a digitech vocalist performer to a pa board
What mixer will you be using it with and how many channels will you need to use it on. After I know this info I can help you.
Thanks
Jan 16, 2011 | Digi-Tech Digitech Vocalist Live 4...
Im Thibking about buying a PA 800 in France because we work every summer here but we also perform in Us... It will work There??? is the same AC adaptor???
excellent question, there is prolly a different plug and its most likely a EURO cable , so yes you DO need the adapter should be able to get it there at the place your buying it at...and it ALSO needs to be able to ron on 110v (us standard) vs. the 208 or what ever the euro wattage is. if its switchable but you CANT find an adapter, buy a female end at the hardware store in france then when in US get a runner to goto the hardware store and get a male edison and 1 foot on 12-14 gauge wire and make one simply enough...IT NEEDS TO BE SWITCHABLE
Jun 19, 2009 | Korg Pa800 Synthesizer
SMF converter for wk-500, Does it exist?
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
Korg pa800 mic input makes funny noise
First turn the unit off then rotate the input level volume control. If it feels loose pull up lightly on it as you do this. Also rotate all your controls that you don't normally use a lot. Chances are the pots are dirty. If that doesn't help you might want to check all the connectors inside the unit if you feel confident enough to go poking around. Other wise I suggest that you find a shop that will fix the problem. If you do go poking around make sure the units unplugged and that you have grounded yourself against static discharges.
Nov 26, 2008 | Korg Pa800 Synthesizer
Midi
Anvil Studio is an easy way to prep midi files for keyboard use, save channels 3 & 4 "left & right" in Midi 0 format and it will light the keys properly. Keep your file size under 80k!
Oct 26, 2008 | Casio Lighted Keyboard LK90STADMC
Korg Pa800 Synthesizer Logo
88 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
