Sharp AL 1641 CS error message "L" - Office Equipment & Supplies
Frankly, I'm not sure how it resolved itself.
I took the glass off because the lamp was not moving across the bed. I manually moved the lamp to the far end of the bed with the power off and then I turned the power on. With the glass and some trim off, I turned the power back on, the lamp went back to it's "home" position, and it didn't work. I powered off, put the glass and trim back and powered on, and it worked.
I just got lucky I guess. Go figure.
Posted on Dec 11, 2008
Can you help: when you turn on the copier AL 1641 CS performs its start-up, pressing enter to copy the scanner remains in the home position of left side
Sounds like the scanner latch is in the locked or latched position. You can hit them easily removing the copier. Look under the area you remove your copies. On the bottom of the scanner, there is a latch lever. Flip it to the unlocked position.
Feb 03, 2011 | Sharp AL-1641CS Laser Digital Copier
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
My unit is Flashing H Then 4. Sharp AL-1641 CS. What is wrong
When this machine H 4 flashing
problem: Fuser unite over temperature
Solve: Press C Exposure button again C Exposure button 14 press start key
C exposure c exposure p 14 press start
Or H4 fixed
Solve: Replace Heater lamp or heater fuse
Dec 16, 2009 | Sharp AL-1641CS All-In-One Laser Printer
I HAVE A SHARP AL 1641 CS COPIER AND THE DRUM I WAS GIVEN WAS SHARP AL 1000 DRUM UNIT AL 100 PART MS1DR AND THE DRUM LIGHT IS STILL ON AND THE COPIER WON'T WORK, DO I HAVE THE RIGHT DRUM AND IS THERE...
The AL1000 drum unit is the same as the AL1641 drum.
I do not recognize the MS1DR as a sharp part number.
You can reset the drum indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
This should make the copier operational again if all you have is the drum light.
Dec 02, 2009 | Sharp AL-1641CS Laser Digital Copier
Toner issue with several third party toner cartridges
Here is the manual for that machine ( incase you don't have it, check out page 59
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=fcb5a95908d7e226bcd8ab88b0637b4f&q=Sharp+AL-1641CS
$100 for toner, wow, try these guys, I've used them and their services are good. Not sponsoring.
http://www.precisionroller.com/k_sharp_al-1641-cs_toner_cartridge/m180d4669c36/
Oct 22, 2007 | Sharp AL-1641CS All-In-One Laser Printer
96 people viewed this question
jasbo
jasbo
