Question about Samsung CLP-500 Laser Printer
Hello my printer says there is a waste motor error where is the motor found?
  • 193 Answers
Remove the waste container..front of the printer.
remove the casing..lower area, you will see a wee motor.
more than likely, use a vacuum to unclog the waste auger.
Posted on Sep 24, 2009
3 Suggested Answers
  • 217 Answers
SOURCE: Waste Motor Error message on Samsung CLP-500
This error is caused by the Waste Toner Motor 'stalling' - usually as a result of the Waste Toner Full message being ignored for too long, and the waste system becomming overful.
Usually best to replace the Waste Toner Motor assembly.
They are for sale on auction websites from time to time.
Posted on Sep 17, 2008
  • 726 Answers
SOURCE: waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
Posted on Oct 02, 2008
How i can fix this problem 929:fatal error .
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
May 16, 2014 | Xante Ilumina Digital Color Press Printer
Waste motor error
Oct 02, 2008 | Samsung CLP-500N Laser Printer
Xante fatal error 929
Feb 11, 2014 | Xante Ilumina Digital Color Press Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
, printer error 5B00
Hello
Error code 5B00 indicates absorber full error. To fix this problem you need to reset waste absorber counter and replace waste ink absorber.
Hope this helps
Jan 18, 2011 | Canon PIXMA MX310 All-In-One Printer
My printer is flashing "E" & then "3" will not print or scan, what do I do?
As antiochpc said we don't know what printer you have. So the best thing to do is to contact the manufacturer website or the forums their you can ask questions. After doing some research I found this I hope it helps.
ERROR CODE CANNON MP150/MP160
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Here is the entire link to the site http://www.fixyourownprinter.com/forums/inkjet/44590
Jul 03, 2009 | Canon Office Equipment & Supplies
Sep 12, 2008 | Samsung CLP-500 Laser Printer
Hello from tita
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Mar 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Waste motor error
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
This is a Canon PIXMA MP 780!!! Waste Ink Full Problem
You can try to read these articles on how to reset the waste ink full error on canon printer. http://www.fastrepairguide.com/waste-ink-full-error/how-to-repair-canon-ip1000-waste-ink-full.html http://www.fastrepairguide.com/waste-ink-full-error/canon-waste-ink-full-error.html They even provide the service tool program for reset the printer eeprom data(set as factory default).
Sep 10, 2007 | Canon I990 InkJet Photo Printer
Samsung CLP-500 Laser Printer Logo
230 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
