Question about HP DeskJet 5650 InkJet Printer
HP DESKJET 5650 - DOES NOT PRINT ON ANY PAPER
I have a HP DESKJET 5650 printer with brand new ink cartridges all set up correctly. It receives print jobs OK, but it does not print off anything !
I've checked the cartridges and they look ok, but I did notice the carriage that holds them does not appear to be touching the paper to print on it.
Does anyone know how to fix this ? Any help is much appreciated.
Regards, Lorraine
    President:
  • HP Master
  • 990 Answers
Hi dear; When you put in the new cartridge ,did you removed the plastic seal(tape)?
Posted on Dec 29, 2008
My HP Deskjet 5650 will not print in color even though i have installed a new cartridge yet the test page is in color??
Just check your printing property and choose color print and apply the settings and then ok.
Good Luck
Feb 26, 2011 | HP DeskJet 5650 InkJet Printer
Bought new black ink cartridge won't print paper goes through fine white bands go across paper paper comes out with no ink on it
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Align Printheads on the list.
Try Printing Again. I hope I was able to solve your problem. :)
Feb 03, 2011 | HP DeskJet 5650 InkJet Printer
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
HELP PLEASE
Remove one cartridge and close the access door. If the cartridge light goes off, the bad cartridge has been removed. If the light continues to blink, remove the other cartridge and reinstall the first one. If the light goes off, the cartridge in the printer is the good one.
May 31, 2010 | HP DeskJet 5550 InkJet Printer
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Compatibles wont work
Try this:
The HP all-in-one product will print black copies using both the color and black cartridges to create composite black in Normal and Best modes. This is necessary to create the correct grayscale shades.
  1. The color cartridge may be out of one color of ink. Perform the steps in the 'Colors are not correct' section above to verify that the ink cartridges are not low on ink.
  2. Verify that the correct paper type is selected in the Paper Type setting.
  3. Some photo paper has different chemical characteristics than Hewlett-Packard paper. The HP all-in-one is designed for use with HP Premium and Premium Plus Photo Paper. The photo paper, paper-type setting should be used with HP Photo Paper. For other paper brands, it may be necessary to use the plain paper or premium Inkjet paper, paper-type settings.
OR: The ink cartage you have may be defective if is a refilled or recharged cartage.
Jun 17, 2009 | HP DeskJet F380 All-In-One Printer
Hp 5650, black ink not working
try cleaning the copper contacts of the cartridge and the inner area of the slot where the cartridge goes in..
Also go to the Printer & Faxes under Control Panel and open the printer's properties..select Printing Preferences >> Paper / Quality >> under the color section check if "print in greyscale" is checked..
it shud not be checked...
save changes and try to print
Oct 01, 2008 | HP DeskJet 5650 InkJet Printer
HP Problem
I had same trouble, you need new ink cartridges.
Jan 27, 2008 | HP DeskJet 5650 InkJet Printer
Hp deskjet 5650 inkjet printer
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Dec 22, 2007 | HP DeskJet 5650 InkJet Printer
HP DeskJet 5650 InkJet Printer Logo
315 people viewed this question
Seeker5211
Seeker5211
