I am trying to get a acer 6920G 16" screen cheap used or new not alot of cash to be playing with thks ahead guys, paul.
Try this WEB site
LCD screens and Inverterswww.lcdparts.net
OR
You can connect an external monitor to the video port on your laptop.
Power up the monitor first then boot up the laptop and the video will automatically divert to the external monitor.
SOURCE: volume touchpad has frozen on mute
This happened to me.
Power down (shut down) and then remove battery for a few seconds.
This fixed my CineDash Media console.
SOURCE: My acer aspire 6920g can't boot on, it's _ with the black screen.
Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation>
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
SOURCE: How to change the keyboard on an Acer Aspire 6920G-6886
You should be able to plug an external keyboard into this model, and unless you have experience in this area, you should have a technician replace the keyboard.
You can attempt to replace the keyboard, but there is a high risk of damage to the unit.
Place the unit upside down.
With the battery facing you.
You must then carefully remove and keep in safe place the following screws. Remove the screws behind, under and the ones just to the left and right of the battery.
BE CAREFULL and document where each screw comes from, and store them carefully for replacement, as they are different lengths. You will need to place them back in the exact holes they came from or it will cause damage to the unit.
Slide off the hinge caps
Carefully turn unit over and place in an open position. ( like if you are using the keyboard)
Lift the keyboard cover up and towards you gently and just a small amount. As you are lifting it toward you,you should be able to slide it right out.
There are two cables on the middle cover that must not be disconnected.
SOURCE: screen change for a acer aspire 6920g
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
SOURCE: The microphone in my acer 6920 is not working....
i know it sounds crazy ....
but check whether you have connected the jack to mic port (usually the pink )....if it is ok...
next go to start | run | type "mmsys.cpl"
it will bring you the audio options...
go to voice option .....
choose your device....
and click the test hardware....
and also do not forget to check whether the main volume is on or not....
this should solve your problem
thks chris but its 1 pound cheaper there lol.
