Question about Dryers
Timer won't stop in autosensor position
Dryer timer will not move when in the auto moisture sensor mode-it is drying clothes but timer does not move or go into cool down cycle. Timer work correctly in normal timed mode
  • am94 Dec 12, 2008
    Could find any other way to reply to the question of model #-it is Kenmore 110.65922400
  • am94 Dec 13, 2008
    Problem with dryer not turning off in auto sensor mode was apparently with the electronic control card partially disengaged from its base. I found this while looking for the wiring diagram which was located under the control panel cover. I could not pull up the wiring diagram from the email you sent me. The electronic control card is upside down and has nothing to keep it in its base. I guess time and vibration worked it loose-it is working great now. Thanks for your help. A timer or electronic control board would have cost from $75-$135 and the extended warranty ran out last month.
  • Dryers Master
  • 19,396 Answers
It can be a faulty moisture sensor, or a defective timer control board.
Here is described the procedure to test the moisture sensor. It is a service procedure and should be used by a technician.
Parts that can be defective are the following:
1060787 Electronic dryness control board
548375 Dryer timer
Posted on Dec 12, 2008
    Master:
  • 623 Answers
Since the dryer runs just fine, and it's a dial, that probably means water/lint built up until the point that the dial got clogged. I'm unsure as to how the dial itself works although I'd guess it uses some kind of clockwork mechanism like a coo-coo clock to operate on and when it gets to a certain point it'll hit a switch, trapping the dial into one spot and tripping the control system to stop running the washer.
You can probably open it up and vaccum it out. Worst case scenario, you blow $30 on a new dial or better yet, get a fancy extension cord, plug one end into the wall and the other end into an electric timer and then plug the washer into an electric timer if you don't want to touch the internals. I don't see any harm in just leaving it broke so long as it turns off somehow before things catch on fire or melt.
  • 275 Answers
I dont think is a vent problem =, it is obvious that if the timer does not move, then it is only related to the timer not being programmed correctly for that mode, thus you might want to have it checked due to that issue.
  • Alan R
    Alan R Dec 12, 2008
    riight it happens all the time, house burned out bc of driyer, see it all da times on the newspappers.
    Master:
  • 479 Answers
Sounds like the problem is a bad timer.
1.
 The timer is a set of switches engaged by a timer motor driven cam. The timer, through these switches, provides power to different dryer parts, like the drive motor or the heating circuit.
You can see it on the wiring diagram for your dryer.
There is supposed to be continuity between the timer terminals TM & OR when the timer is set for "auto” dry in order for the timer to advance.
There is supposed to be continuity between the timer terminals BK & R in any cycle in order for the dryer to heat.
2. You dryer does not sense moister because it does not have a moister sensor and an electronic moister control.
The difference between "timed" dry and "auto" dry in your dryer (as you can see from the wiring diagram) is:
on "timed" dry, the power to the timer motor comes through the drive motor centrifugal switch as long as the dryer is "on";
on "auto" dry, the power to the timer motor comes only when the heating circuit is "off" which actually makes the whole cycle longer.
  • 734 Answers
Please give me the model number.
  • 1 more comment
  • futureloginn
    futureloginn Dec 12, 2008
    ck vent to outside starting at back of dryer looks restricted or flatten vent hose then ckd vent from wall or floor to outside to verify problem is vent issue leave vent hose off and try a load may get a little warm and dusty but would be quick way to verify
  • futureloginn
    yes if you want than contact me,, at my FixYa  id
  • futureloginn
    Check all vents and clean the filters.
    There should be a blower fan inside that circulates the air when the heating element is on.
    If the fan is not circulating the air properly, the heat will build up.
    There is also a problem of accumulation of lint in the air ducts.
    This should be removed.
    There are numerous occurances of similar problems to yours resulting in fires, due to excess heat and lint build up.
    PLEASE be aware of the safety issue in resolving this.
    Thanks.
The dryer does not pass 6 min mark and does not shut off. How would I test a humidity sensor? Thank you for help.
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one.
1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing.
The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away.
Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off.
2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
Sep 08, 2013 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
My Maytag dryer LDE7304ACE will not turn off. It heats and dries but the auto dry dial never moves once it is set (I can't remember if it did move when the dryer worked correctly). It does not shut off...
try cleaning the moisture sensor bars just inside the door and below the door,with isopropyl alcohol of course after unplugging the unit for fire safety,these 2 chrome colored bars detect the moisture in the clothes and when they are wet they slow or even completely stop the timer,as they dry they let the timer again move,if they get a film on them they will not operate the timer correctly,they work on capacitance
Apr 27, 2011 | Dryers
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Dryer will not turn off
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Mar 26, 2009 | Whirlpool Dryers
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Auto feature
Faulty selector switch or control card. There is the possibility of a faulty moisture sensor. Can you operate the machine in manual mode ?
Jan 26, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
108 people viewed this question
Top Dryers Experts
