Question about Whirlpool LSR5132PQ Top Load Washer
Washing machine will not operate
When I pull the knob to turn on the machine nothing happens. I've checked the power at the outlet and it is good. Power is getting to the machine via the cord but does not do anything once I pull the knob to turn it on, doesn't fill with water or anything. Just silence.
  • Anonymous Jan 04, 2009
    mine filled up and now doesnt work
  • 640 Answers
Check across your lid switch
Posted on Dec 27, 2008
How to reset brandt washing machine
Stopped or Won't Start If the washer won't start or has stopped during a load, verify it has power. Plug a nightlight or other device into the power outlet to test it if you can easily access it. Otherwise, check the circuit box for a tripped breaker. Open and close the lid or door of the machine. If the washer stopped during a wash, adjust the load so that it is balanced. Check if the drain hose is clogged, and clear if needed. Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work. On some machines, hold down the button labeled "Start-Pause" or "Stop" for a slow count of five. Turn the washing machine on. Run a rinse and spin cycle to check that washer is working and that the error code, if applicable, cleared.
Washers Without a Reset Button If it isn't possible to access the washing machine's plug to manually reset the washer, turn off the circuit breaker. Leave it off from 30 seconds to 1 minute, depending on the machine model or instructions in the owner's manual. For washers with a knob control, turn the dial clockwise to any cycle other than "Final Spin." With button controls, select any cycle other than "Spin." Check that the water to the washing machine is on. Turn the breaker back on. Turn the washing machine on. Some machines require that you open and close the lid six times after plugging the machine in to reset the motor.
When Reset Doesn't Work In some cases, after using the reset button -- or resetting the washer manually -- nothing happens. Your machine may have a problem or a faulty part that keeps it from operating. Among the most common are problems with door switches, latches or a faulty timer that may require replacement. Authorized technicians can replace parts or service the washing machine as needed. Websites of major manufacturers have replacement parts available to order and some provide schematics or answer your questions. On a recent-model washing machine, check if it's still under warranty.
Aug 14, 2016 | Brandt Washing Machines
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Hotpoint aquarius washing machine
If you have pressed start or pulled out the knob of the cycle unit and nothing happens I would be checking the operation of the water inlet solenoid . If it is not getting power or it is not opening the valve to allow filling to commence there will be no further action of the machine until the tub is filled to the desired level.
Aug 17, 2013 | Washing Machines
Need help I have a Model #11015852400 washing machine totally dead, the outlet has electricity , nothing happens when pull the starter knob (do they have some kind of fuse? that is what it feels like to...
hello check the glass fuse inside the washers power supply make sure you use the same rated fuse if it blows again then theres a dead short somewhere hope it helps
regards
shaun
Apr 04, 2011 | Washing Machines
Will not turn on
# 1 reason for service call is the machine is not plugged in. Make sure outlet has power and washer really is plugged in. If not, then something inside is bad and needs to be taken apart. If absolutely nothing happens, then switch is bad.
May 26, 2009 | Maytag Washing Machines
Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
Entire range doesn't operate
skimmerle check your connections where your cord attaches to the stove.may be burnt or loose.if ok check wall outlet also 4 loose connections.i think whats happening is you turn the knob and that allows one side of the power thru to the clock so comes on /then turn off power drops out.give what ive said a good visiual inspectionGod bless,tom
Jan 01, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Whirlpool LSR5132PQ Top Load Washer Logo
155 people viewed this question
Dan Webster
Dan Webster
prem mathew
