Question about Canon imageRUNNER 400S Copier
Canon IR3170CI got a error E0014-002
Got a error E014 changed the fuser,transfer belt, fixing motor, DC controller, circuit boards and changed the fuser temperature on the service mode can you tell me where the fixing motor rotation and any other suggestions to solve this problem? Can anyone at all help me? please
  • 168 Answers
K these are notorius for having bad upper rollers if they sit for a long time if you turn the green knob on the fuser and feel hesitation or its hard to move then easy.. or if it sounds like a washing machine at warm up you need a new fuser even if youswapped it the one you put in if not new may be bad
Posted on Dec 10, 2008
Cannon Image Runner 400S has an ERROR E014 (Fuser Drive Issue), how to fix it
your fixing motor has faulty rotation.
check main motor M2 , DC Controller PCB and image processor pcb
Apr 06, 2011 | Canon Office Equipment & Supplies
Tip
ERROR codes Canon 8570
Canon 8570 E000 Fuser problem. Temperature too low. Heat lamp, thermal fuse or thermoswitch, thermistor, triac etc E001 Fuser problem. Temperature too high. Probably triac E005 Fuser web finished E005 Fuser cleaner belt user up E010 Drive E010 Main drive problem E011 Drive problem. Could be main motor, scan motor, cleaning web motor or duplex motor E011 Main motor, scan motor, cleaner belt motor, duplex motor, toner motor, lens motor or driver bd. for any of these E020 Toner sensor problem or lack of toner feed. This occurs if toner feed signal is present for 3 min E020 Toner empty sensor sees no toner added for 3 min probably toner feed problem E050 Duplex problem E050 Duplex problem E203 Scan motor problem E203 Scan motor E210 Lens motor problem E210 Lens home sensor or lens won't leave home E240 DC controller board E240, E241, E242 Control board (main board) E241 DC controller board E242 DC controller board E243 Operation panel board E243 Operation panel E400 DC controller, ADF board or 24V E400 DC controller or document feed board E500 DC controller or sorter board E500 DC controller, sorter board or 24V E510 Finisher; feed motor, pulse sensor, finisher board E510 Finisher E520 Finisher; stack motor, stack tray sensor, finisher board E520 Finisher
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 8070
Canon 8070 E000 Fuser problem. Temperature too low. Heat lamp, thermal fuse or thermoswitch, thermistor, triac etc E001 Fuser problem. Temperature too high. Probably triac E005 Fuser web finished E005 Fuser cleaner belt user up E010 Drive E010 Main drive problem E011 Drive problem. Could be main motor, scan motor, cleaning web motor or duplex motor E011 Main motor, scan motor, cleaner belt motor, duplex motor, toner motor, lens motor or driver bd. for any of these E020 Toner sensor problem or lack of toner feed. This occurs if toner feed signal is present for 3 min E020 Toner empty sensor sees no toner added for 3 min probably toner feed problem E050 Duplex problem E050 Duplex problem E203 Scan motor problem E203 Scan motor E210 Lens motor problem E210 Lens home sensor or lens won't leave home E240 DC controller board E240, E241, E242 Control board (main board) E241 DC controller board E242 DC controller board E243 Operation panel board E243 Operation panel E400 DC controller, ADF board or 24V E400 DC controller or document feed board E500 DC controller or sorter board E500 DC controller, sorter board or 24V E510 Finisher; feed motor, pulse sensor, finisher board E510 Finisher E520 Finisher; stack motor, stack tray sensor, finisher board E520 Finisher
Getting error on machine E014 what do I do
This error usually indicates that the fuser drive motor cannot drive, or rotate properly. It could be a seized fuser assembly, (aka Fixing unit), broken drive mechanism, faulty DC Controller PCB.
It can also be caused by unstable rotation of the fixing assembly, or main motor.
Jan 27, 2010 | Canon imageRUNNER 400S Copier
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
Tip
ERROR codes Canon 6045
Canon 6045 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace, same possibilities as E000. E003 Fuser temperature drops. Same as E000. E004 Fuser problem: AC driver, SSR bad, wire shorted. E005 Fuser cleaning web, or problem with sensor, lever or connector. Service mode 6 is the probably reset for this. E006 Fuser feed connector. E010 Drive problem. Main motor, gears, etc. E013 Waste toner drive problem, or waste toner sensor switch has been actuated too many times. E015 Pickup motor power supply. Could be bad motor or motor board, or DC controller. E020 Problem with developer unit, toner hopper, hopper motor, connection, sensor or DC controller. E030 Total counter. E031 Option counter or total counter. E050 Holding tray (duplex) home position sensor motor or board. E051 Holding tray (duplex) home sensor motor or board. E202 Panel locked up, but might be no code, scan motor problem. E203 Scan problem or scan sensor E204 Scan problem or scan sensor E210 Lens sensor or motor problem E212 Lens sensor or motor problem E213 Scan lock sensor or lock solenoid E220 Exposure lamp regulator board E240 DC controller or composite power supply problem. E243 DC controller E400 RDF to copier communication problem E401 RDF pickup motor or pickup sensor. E402 RDF belt motor or pulse sensor. E403 RDF feed motor or pulse sensor. E411 RDF tray sensor or registration sensor E500 Sorter main board or communication with copier E510 Sorter feed motorE522 Sorter push bar motor E523 Sorter reference wall motor E524 Sorter multi-guide motor E525 Sorter bin paper sensor automatic adjustment problem E526 Sorter bin paper sensor automatic adjustment problem E530 Sorter guide bar motor E531 Sorter stapler motor E532 Stapler motor E533 Stapler inside paper sensor E540 Sorter bin shift motor E550 Sorter power supply E710 DC controller E711 DC controller E712 Document feeder IC failure E713 DC controller, sorter E800 Auto power off circuit problem. Main switch or DC controller. E802 Auto power off circuit problem. Main switch or DC controller.
Tip
ERROR codes Canon 3050
Canon 3050 E000 Fuser temp low. Heat lamp, thermoswitch, thermistor, SSR E001 Fuser temperature too high or shorted thermistor E002 Fuser temperature too low E003 Fuser temperature too low E004 SSR, or lamp reg. board E010 Drive problem E022 DV unit switching problem E030 Counter not working/open E202 Scan problem. Scan sensor, scan motor E204 Scan problem. Scan sensor, scan motor E210 Lens problem. Lens sensor, lens motor E220 Exposure lamp E240 DC controller (main board) E400 RDF circuit board E401 RDF pickup motor drive E402 RDF belt motor drive E403 RDF feed drive problem E404 RDF exit motor E411 RDF sensor problem E500 Sorter board problem E510 Sorter feed motor E512 Sorter delivery motor E514 Sorter delivery motor E520 Sort stack motor E530 ******** motor E531 Stapler motor E535 ******** motor E540 Shift problem E541 Shift problem E710 DC controller E711 DC controller E712 DC controller. Document feeder board or cable
on Jan 18, 2010 | Office Equipment & Supplies
IR400 ERROR CODE E014,E806
E-014 - The fixing motor has a problem. This can be the fuser drive motor, DC Controller, or Image Processor circuit boards. The only time I've had this problem is with one of the fuser bearing going bad and causing excess drag to the motor, giving you the error. See if the green fuser advance knob is hard to turn. If so then check the bearings.
E806 - This is not in the book that I have. Be sure of the number.
E-805 - There is a fault with fuser cooling fans ( located on the delivery door )
Nov 20, 2008 | Canon imageRUNNER 400S Copier
Tip
ERROR codes Canon 3030
Canon imageRUNNER 400S Copier Logo
506 people viewed this question
old marine
old marine
