Question about HP OfficeJet 6110 All-In-One InkJet Printer
I keep getting the paper jam message but had taken everything out and cleaned it.
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Posted on Dec 10, 2008
I have a new Pixma printer. I got some paper jammed in the printer. After I removed the paper and pressed OK, I still get the error message "Rear cover The paper is jammed. Clear the paper and press...
Make sure all the paper bits are taken off , now to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 29, 2010 | Canon Office Equipment & Supplies
I keep getting the message "Out of Paper" or alternatively, "Carriage Jam" The printer is not out of paper - I have removed, straightened, added paper and it's the type I have always used. There is...
It will be good to have the printer mechanism jammed or the paper tracks jammed with paper struck in the roller.
Remove all connections when the mechanism is taken out cleaned and drives checked manually with the motor removed and the drive turned to see that the movements are smooth.
make sure the input sensors are intact , the paper detection sensors.
Sep 24, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
We keep getting a message -paper jam check open rear door. checked, no paper jam, opening and closing rear door will allow the print job to go through. It will work for a few print jobs, then the same...
It's probably a sensor on the fuser. There are 2 and sometimes they get stuck and just closing the rear door hard will release it. Replace the fuser.
Dec 08, 2009 | Dell W5300N Laser Printer
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Cannot print - keep getting paper jam message - after pressing cancel button, paper keeps feeding into machine w/ paper jam message again
Hi
try cleaning the paper jam first
check out the following link,this should help you a great deal
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=us&lc=en&dlc=en&product=422000
Jul 14, 2009 | HP PSC 2355 All-In-One InkJet Printer
Jammed paper message
I get a Jammed paper message on the read out, I have cleaned out all the paper and pressed stop/cancel button but it still keeps saying that there is a paper jammed in it.
May 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Paper Jam with no Jam
We have the same problem. Do not by shit next time
Nov 12, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
