I have a GSS25XSSQA SS refrigerator.It seems to have stopped making cold. The back panel of the freezer is covered with frost. The ice is not being made and water dispensed but isn't cold. the freezer side still feels cool, but meat is slowly defrosting. The refrigerator side feel warmer. on the control panel the turbo cool indicator is on. What can I do?
Frost buildup on the rear panel of the freezer indicates a defrost problem. Your model has the defrost timer built into the motherboard and for some reason that is unlikely to fail. What does go bad is the defrost heater and the defrost thermostat on your GSS25XSSQASS. Click HERE to view the parts listed as location 240 and 230 GSS25XSSQASS Freezer Components
The defrost heater is listed as location 230 in photo Here is a Link=> WR51X10042 Defrost Heater Assembly
And next is the part in photo listed as location 240 That is the defrost thermostat=> WR50X10068 Defrost Thermostat
hi maria .a bit vague on details but if evaporator is frosty then defrost everything for 24/48 hours.to accelerate procedure use steam ;hair dryer;heater .(not too close with heat.u dont wana melt the plastics).then try.u might get lucky.if not u need internal check. 1-door seals 2-defrost timer 3-heaters 4-t/stat.5 pcb.hope this helps good luck.Ali
