Question about Olympus Stylus 800 / ? 800 Digital Camera
Plug it in a wrong AC adoptor
I mistakenly plugged it in a wrong AC adoptor and wouldn't turn on. is there a way to fix this? would you know how much it will cost to fix this?
    President:
  • 919 Answers
You will need to call Olympus Customer Service for repair pricing and information. Their phone number is 800-622-6372 option 2 and then option 3.
Posted on Dec 10, 2008
HP screen goes black 5 seconds after ac adapter is plugged in or out
This may not be the ac adapter itself. the metal prongs on the side of your HP Laptop to connect to the wire of your ac adapter may be bent or shortciruited. try to get a replacement which may be hard depending on what type of HP Laptop you own. or you may just have to send it back if you dont know how, in order to avoid breaking the warranty policy by mistakenly damaging it.
Apr 18, 2013 | Computers & Internet
My ac adoptor has a storhage and I need a new one where can I get a new one(ACpower adaptor)
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
Mar 24, 2011 | Sylvania G-Netbook
Hello. I have a problem with my ZOOM H4 recorder. When I try to turn it on (using ZOOM adaptor) it shows the the battery is low (but batteries aren't included) and tells me to turn it off. Also, when its...
I have exact same problem, I got it to work temporarily by turning unit on then connecting AC adaptor into unit, it forced it to run, I formatted card and it worked for an hour now back to same old problem, I'll keep you informed. I believe it's faulty switch. help me if you can.
Oct 07, 2010 | Zoom H4 Handy Recorder
I have a Gateway 4525GZ power problem
your ac adoptor is not correct it is low amh
please check for original adoptor
Jul 30, 2009 | Gateway 4525GZ Notebook
LI 6000 2-way charging base does not charge- no indicator light
Dear sir,
It seems that ur adoptor is not ok , u can save the money by purchasing any 9 V adoptor, It available for less than 1 USD in our country ..& cut the wires of ur budled adoptor & fix them in correct polarity with the wire connecting the charger base ..( before doing this proces check voltage output from adoptor by using a multimetre.)
Regards
Raj
Jan 12, 2009 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Plug it in a wrong voltage
your SMPS must have burnt and needs to repair. Contact some harware engineer
Dec 10, 2008 | Olympus Stylus 800 / ? 800 Digital Camera
19v 4.7amp hp 6000 adoptors
Any 19V 4.7A adapter with a plug that fits the jack will work regardless of what it looks like. Radio Shack sells adapter plugs that will fit any jack if you cannot find the exact HP replacement.
Nov 05, 2008 | HP Ruggedized DC Car Adapter for HP...
Laptop wont turn on anymore.
poncha,
Your battery might be dead and it might cause problem to boot.
  • Remove battery, insert A/C adoptor and try to boot normally, if success then you should change your battery and all will be fine. If no success then try next step.
  • Remove battery, remove A/C adoptor. Press and hold power button abt 10 seconds then insert A/C adoptor holding the power button on. Keep holding for 30-45 seconds. If still no success then have a tour to the service centre.
Thanks & Good Luck
Iqbal
May 18, 2008 | Dell Inspiron B120 Notebook
Toshiba a100 laptop
Definitely try without the battery. These models are known to have a "short" problem, usually with the palm rest, which causes this failure, although it usually is more sporatic, and doesn't happen 100% of the time.
Also, can you remove all but 1 piece of memory.
Good luck, and let us know what happens.
Mar 19, 2008 | Toshiba Satellite A105 Notebook
No power
I had the same problem, basically as you said if you took apart the laptop, and put it back together and your sure you didn't screw anything up, unplug the cord from the laptop, and take out the battery wait 1-2 hours, more if necessary. DON'T plug the battery in, and just plug the AC in and try and turn it on. Hope this helps.
Oct 22, 2007 | Toshiba TE2100 Notebook
Olympus Stylus 800 / ? 800 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
