Question about kawasaki Full Suspension Mountain Bike Men
Wont run got it to pull start but did not stay running when kick starting trys to start has fuel and spark
    Problem Solver:
  • 7 Answers
Hey Chad,
The first thing I would do is a compression test. You say you have spark, but have you actually tested the strength of the spark ? A simple check to see if the spark is strong enough is to take the spark plug, hook it up to the spark plug wire, hand hold the shell portion of the plug roughly a 1\2 inch away from the cylinder head, and crank the engine over. If the spark jumps this gap, you have good spark. If it doesn't jump this gap, your ignition coil or stator coils maybe weak and not producing enough voltage for a good spark.
Posted on Dec 11, 2008
Kawazaki kdx 125 wont start
KICK HARDER TRY PULL STARTING IT..IN SECOND GEAR..DOES IT HAVE ENOUGH COMPRESSION TO START?IT SHOULD START PULLING IT...START OFF WITH NO THROTTLE THAN IF NOT STARTING CRACK THE THROTTLE SO LIGHTLY AND SHE SHOULD FIRE OFF WHILE IN GEAR BEING PULLED OF COURSE BE CARE FUL NOT TO RUN INTO. WHO EVERS PULLING YOU..USE A LONG TOW ROPE..IF YOUR NOT A SEASONDED RIDER AND KNOW YOUR BIKE VERY WELL I WOULD NOT ATTEMPT THE PULL START...IF NOT CHECK YOUR COMPRESSION AND TIMING..MAJOR VACUUM LEAK MAYBE AT BASE GASKET..IS ENGINE SUCKING TO MUCH AIR? GOOD LUCK..
Mar 02, 2013 | kawasaki KDX 125 Motorcycles
2000 chryler concord trys to fire but wont start can smell gas though 2.7 engine
Was the car running and quit or would it not start after setting?
Jan 12, 2013 | Cars & Trucks
1999 volkswagen cabrio, wont start on its own, replaced the fuel pump, replaced in jectors, it WILL start when kicked off with starting fluid...but wont stay running...
I think you should open you exhaust in front of your catylitic converter. Pull the O2 sensor or just take the pipe off.
Jul 11, 2012 | 1999 Volkswagen Cabrio
Car wont run or start motor okay starter okay gauges okay battery okay fuses okay maybe key switch maybe something else
F >> Fuel
A >> Air
S >> Spark
T >> Timing
Have you checked to see if you're getting fuel? Bad injector
Bad Coil Pack(s)?
Are you getting a spark from your spark plugs?
Checked vacuum hoses?
Hope this helps
Oct 21, 2010 | 2001 Buick Century
Wont start
pull out the plugs and check for compression,the tappets will be loud if not set but it should start
Jun 07, 2010 | 2002 Honda XR 200
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
V6 camry has spark fuel compression run out of fuel
check for compression it should start if it has spark and fuel nothing but compression stopping it
Mar 25, 2009 | 1991 Toyota Camry
Starts but wont stay running
In reply: if its not the maf there are 2 relays in the relay box i belive its underhood, 1 primes the fuelline to 32psi the second kicks in after it starts, and keeps it running and varies the psi. if the primer relay isnt kicking in then it wont start due to no fuel
THX
Don :)
Jul 26, 2008 | 1991 Chevrolet Camaro
kawasaki Full Suspension Mountain Bike Men Logo
154 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
