Question about Olympus Stylus 800 / ? 800 Digital Camera
Plug it in a wrong voltage
I mistakenly plugged it in a wrong voltaged AC adoptor. is there a way to fix this? and when i trtied to turn it on, it wouldn't.
Your SMPS must have burnt and needs to repair. Contact some harware engineer
Posted on Dec 13, 2008
AC adapter not charging system
The low battery light may be indicating that the battery needs to be replaced.
Nov 28, 2013 | Altec Lansing Inmotion-IM600...
I plugged wrong adapter (dock's proper voltage was
Doubtful, you've plugged it into a voltage of nearly twice its rating. My guess is that you've blown it up.
Oct 30, 2013 | Altec Lansing - IMT320 - inMotion Compact
My ac adoptor has a storhage and I need a new one where can I get a new one(ACpower adaptor)
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
Mar 24, 2011 | Sylvania G-Netbook
Can i open this adapter and check whether there is any problem with the hardware which can be fixed or not ?
This can be opened but it is not designed to be opened and serviced. If you have the correct voltage coming out it is good. Test for DC voltage at the end that plugs into the computer. If the voltage isn't correct check for AC voltage using a voltage tester at the plug and the cord that connects the power adapter to AC source. This is very important, DO NOT CONFUSE THE TWO TEST, this can cause injury and damage test equipment. If AC voltage is present but the adapter is not converting it to DC it is best that you simply replace the unit.
Jan 06, 2011 | Toshiba AC ADAPTER 75W 19V 395A...
I plugged the wrong voltage cord into the monitor, and now the correct cord doesn't work. Can it be fixed?
You may have shorted out the AC plug. You'll need to test it for continuity by using a voltmeter.
If it is shorted out, then you'll need to have the plug replaced.
Jan 21, 2010 | Microtek C593 15" Flat Panel LCD Monitor
There is power to dryer but won't start. the light is on. Voltage to main is 122V AC, voltage to start switch is 59V AC
If I'm not mistaken, your voltage is only half of what it should be. Check your main power supply.
Jul 31, 2009 | GE Dryers
I have a Gateway 4525GZ power problem
your ac adoptor is not correct it is low amh
please check for original adoptor
Jul 30, 2009 | Gateway 4525GZ Notebook
Cannot engage RESET Button on plug to power the 220v AC unit
The reset button is a voltage leak detector it is possible the unit has a short in it or the cord has a short
Apr 28, 2009 | Heating & Cooling
LI 6000 2-way charging base does not charge- no indicator light
Dear sir,
It seems that ur adoptor is not ok , u can save the money by purchasing any 9 V adoptor, It available for less than 1 USD in our country ..& cut the wires of ur budled adoptor & fix them in correct polarity with the wire connecting the charger base ..( before doing this proces check voltage output from adoptor by using a multimetre.)
Jan 12, 2009 | Cobra Li 6000-2 WX VP GMRS/FRS Two-Way...
Plug it in a wrong AC adoptor
You will need to call Olympus Customer Service for repair pricing and information. Their phone number is 800-622-6372 option 2 and then option 3.
Dec 10, 2008 | Olympus Stylus 800 / ? 800 Digital Camera
Olympus Stylus 800 / ? 800 Digital Camera Logo
100 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
