Question about Peerless Industries Peerless& Single Handle Tub & Shower Faucet
Shower temperature too hot
Have shower that switches from overhead to hand held. Has worked perfectly for over 1 yr. Lately the water is much too hot and can't adjust. The other shower, faucets, etc are not having this problem. Is there some sort of routine maintenance?
  • Anonymous Feb 22, 2009
    mine began when we developed a water hammer thumping in the bath area. the valve is now 100% hot or cold, no in between. the hammer is lessened but the hot or cold problem is unchanged.
    we had 2 plumbers come out for a total of 5 visits to solve this problem, and neither could solve it. they replaced the cartridge twice, replaced both outside water spigots, checked and tightened every valve in the house, then threw up their hands and walked away. at least they didnt charge me. so now we live with it.
  • CPKM Mar 15, 2009
    My Grohe shower is about 3 years old and also developed a problem of temp adjustment. It hot or super hot and sometime the water just stop without warning. So far no plumber has the courage to take it apart.
    Should I just replace the whole unit? It seemed like fixing a Grohe is not that easy.
    Problem Solver:
  • 6 Answers
Shower valves that have anti-scald features are renowned for this problem. Usually it is caused by not being used regularly. It can be repaired usually without replacing the valve, but you will have to dissemble it, clean, and use some plumbers grease to reassemble it. It should work fine after this. If it still does not work you will need to replace the cartridge.
Posted on Jul 04, 2009
    Scholar:
  • 68 Answers
From your question it sounds like the valve is around a year old. That means it has a pressure balancing cartridge that prevents scalding when there is a drop in cold water pressure. It seems that that stem is either plugged OR partially built up with water scale. I'm guessing Stem/cartridge is corroded.
Do you have a properly working water softener??
Posted on Dec 10, 2008
What to do if i can't stop the water flowing from the shower spout and there's little water pressure coming from the shower head and a hand held shower?
One rule I live by: more parts, more problems. Sounds to me that the plumbing/valves were not insalled properly. If you hired a profesional plumber, have them fix it. I am a licensed profesional plumber and I offer a 1 year warranty on all my work. If the contractor did the work and does not hold a plumbing license, that person is still responsible and may have to suffer legal consequenses.
Sep 10, 2013 | Latoscana TC3TPW690 Water Harmony...
Clubmaster shower not holding temperature. Hot water not coming through.
There's only there things that are clubmaster, a shower head, and two hand held sprayers.
They all spray water, they don't heat water.
Did someone install a new part, the one that's behind the wall ?
If they did, most have a safety so people don't get burnt and they need to be adjusted.
Apr 16, 2013 | Hansgrohe Clubmaster Showerhead, Steel
Adjust hot water on hansgrohe metro shower
The hand shower and wall bar does not control temp. The valve in the wall would control the temperature of the water going to the shower. I would need to be able to identify the model number of the valve in the wall to be able to give accurate instructions on temperature adjustment. If you need help identifying this valve feel free to give me a call at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough
Oct 13, 2012 | Hansgrohe 06496 Croma Hand Held Shower -...
Hi, We have a old 5-port diverter valve (Grohe 29 605) in our shower in which the outlets are connected thus: Hand held shower port connected to hand held shower Fixed head shower port connected to body...
yep replace the unit the plumbing will be ok for a new unit, with a setup lie that whoever installed it hopefully was smart to put shut off valves behind the wall or you will have to turn off h20o supply and replace and solder caps on the rest easier to change out to new
Mar 04, 2017 | Plumbing
I'd like to install 1 shower had and one hand held shower. What do I need to have ?
well you can do a 3 way shower valve , or a mixing valve with 2 control valves. or you can do just to regular shower valves one for each of the heads you want one for the rain and one for the shower head. this way is cheeper and you can have one on hot water and the other cold water or the other way around or both the same temp.
Apr 26, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
No hot water
Sounds like the temperature limit stop in the control needs adjusted
May 24, 2009 | Home
Triton Electric Shower Temperature too hot
You could have mineral deposits on the temperature probe inside of the unit. If you remove the heater and purchase a bottle of lime and scale remover (lime away) to put inside of it. Let the unit sit full of water and chemicals for 24 hours. Flush out the unit to remove any residue. You may see the water is brown if you have a lot of buildup. Reconnect unit and test your settings. If this doesn't work, install a anti-scalding device, available at a plumbing supply store.
Oct 22, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Peerless Industries Peerless& Single Handle Tub & Shower Faucet  Logo
3,746 people viewed this question
Top Peerless Industries Home Experts
Joe Lamb
Joe Lamb
john h
Steve Wood Plumbing...
Level 1 Expert
Are you a Peerless Industries Home Expert? Answer questions, earn points and help others
