Question about ASUS P5RD1-VM Motherboard
Do not support 2 HDD at a time
I have Asus P5B -965 Intel Chip. Now i face a problem which is not in times of two months ago. whenever i connect two HDD at a time and try to boot from one of them, the computer restarts it self. If i run single HDD both run well as i have Windos XP loaded in both the HDD . Please help
  • 395 Answers
Make sure the jumper on the hard drive has 1 set to master and the 2nd one to slave. or set them both to cable select. i bet you have them both set to master and thats why it only boots when you have just one hooked up
Posted on Dec 10, 2008
Computer won't resume after standby (os: vista)
Make sure all Vista updates have been installed, and check the ASUS website for any bios updates. I believe that motherboard had a known issue with stand bye.
Oct 18, 2009 | ASUS P5B Deluxe Motherboard
Want to run both Raid 5 (4 drives) and a single SATA boot drive
Download the latest beta BIOS 1238. I had the same problem when adding a Samsung 1TB HDD to my RAID config. Updating to BIOS v1238 solved the Intel RAID Matrix "hanging" instantly.
You can't download it through the official Asus support page yet, but there's a topic in the Asus support forum with a link. You could also call Asus support and request the file, or just download it here: http://rapidshare.com/files/186891601/P5B-Deluxe_1238.rar :)
Feb 07, 2009 | ASUS P5B Deluxe/WiFi-AP Motherboard
AHCI
choose RAID mode.. that should enable AHCI. (as per wikipedia) on your motherboard so that means.. that if you're installing the os on this hdd you may want to use the raid driver for it which is likely what's in the ASUS cd you got so your os get to use the hdd as it's meant to be used.
you may also want to make sure you're using the right sata connector on your motherboard: check page 33
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5B-VM/e2642p5b-vm.pdf
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5B-VM
the problem could laso lay in your cables.. it's know the average may be affected by faulty SATA cable or faulty SATA power cable (powersupply issue)
you may also want to run a backup of your data and then run a defrag and a checkdisk on the drive, and it's probably also worth it to rung Seatools (download from this page: http://www.seagate.com/www/en-us/support/downloads/ ) to check the health of your hd.
Also try to update the SATA controller drivers or the motherboard chipset
lastly, post the results of your tests here on fixya or better yet: in here: http://forums.seagate.com for further follow up.
try each recommendation one at a time and then test the speed of your hd to see if there's improvement.. make sure you back up before you do anything drastic.
good luck (it took me 2 hours to pos
Dec 14, 2008 | Computers & Internet
Asus p5b-mx motherboard not showing display but every thing is on
Hi camlamm, check out Asus CPU supported list link;
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5B-MX&os=17
See if your CPU is in the list.
Bios not booting? If you are receiving any display on your monitor the trouble is not the graphics card. Suggest you clear the cmos jumper. See page 1-26 instructions your manual. This Asus board is warranted for three years. If nothing gives you access to the bios, suggest you call Asus tech, M-F, 8:00AM to 5:00PM EST at: 1-812-282-2787.
Good luck camlamm!
Thank you for using fixya.
Mike
Dec 11, 2008 | ASUS P5B-VM DO Motherboard
On Asus p5b-mx motherboard no beep no lcd no bios only fans and l
Check your Video Card. Perhaps Bad driver or a malfunction
2 Sata HDD not working at a time
In the bios be sure that all the parameters for the SATA drives/devices are AUTO
Dec 11, 2008 | ASUS Motherboard P5B-SE P965 LGA775 Core2...
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
Intel upu ucode loading error
While starting computer a msg appear " intel upu ucode loading error" after pushing F1 computer get start my computer having ASUS mother board P5BMX/WIFI-AP and intel core2duo procesor Please help
May 19, 2008 | Computers & Internet
Help!
Have you installed RAM? If not the machine will not boot. You may also need to enter the BIOS setup to set the CPU and DRAM voltages and multiplyers etc. Follow the instructions in the manual for setting up the CPU info in the BIOS. Are you sure your PSU has enough guts to run the setup? Many times have i seen setups fail because a cheap power supply has been overstretched.
Jun 14, 2007 | ASUS P5B Deluxe/WiFi-AP (P5B DELUXE /WIFI...
ASUS P5RD1-VM Motherboard Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
