Question about Gigabyte GA-K8VT800 Motherboard
No post start up
Hi,..i just bought a ga k8vt800m motherboard...used...i'm trying to set it up. it won't post start.. no beeps..no video...i see the cmos reset and has two pins...? what is the normal position ...jumper on the two pins or open? thanks.....iwill post as i progress
  • Sandy Ruiz Dec 10, 2008
    hi..what i need is to know the proper position of the jumper..on or off...thanks for trying
Jumper on the two pins
martin
Posted on Dec 26, 2008
    President:
  • 2,110 Answers
Only try to remove the cmos battery and reinsert again.......
Posted on Dec 10, 2008
My system won't boot but there is power
The things to check when your system will not post are RAM (make sure it is in all the way) Hard Drive (make sure it is properly connected) Your CD/DVD drives (again check connection) and your video connection (if you have onboard graphics, this may not apply, if you have a seperate video card make sure it's properly secured in the PCI slot)
Once you've checked all of these things, if you still have a problem, listen for the beeps that come from your computer's motherboard and remember the order of short and long beeps. Respond with the beep sequence and type of computer you are using.
Cheers
Jun 01, 2012 | Gigabyte GA-G41M-ES2L Motherboard
GigaByte GA-8EGXR-P motherboard beeps when turned on - no video or BIOS - system does not boot
hi try to clean memory ram....clean it using eraser.....most of motherboard beep if memory not detected....or try other memory ram
May 10, 2011 | Gigabyte GA-8EGXDR-EL Motherboard
Dear Fixya, my GA 6bx7 (Intel bx440) , GA GF400mx,JNC 235 W Power,Cel 900Mhz start clicking just seconds after (or during) Post (no Hdd ). In Bios signal sound more loudly. There is second or more...
your hard drive is dying or dead,mouse and keyboard ps2 will normally work with operating sys,try with another h/drive should work clicking are heads crashing good luck!
Jan 08, 2011 | Intel Motherboard
Not getting any POST (nor beeps) and monitor states "please check signal cable".
If there are no beeps, your computer is failing the POST. I'm assuming the system is actually powering up--you didn't say it doesn't.
I would disconnect all peripherals (HD, CD, any cards) and try to start with just the CPU, memory, and video. You could also swap memory sticks if you have more than one.
If it still doesn't start, I'd guess the motherboard is toast.
Oct 15, 2010 | Gigabyte GA-6VTXE Motherboard
When i reset by desktop bios is not loaded (i think) black screen and not disk activity. Ga-k8vt800m. this happened after cpu frequency change.
If you can still go into the BIOS screen, disable the change you made and see if the system returns to normal.
If not, and you do not remember the settings, go for the default...
Ground yourself to the chassis to dissipate static electricity, with the system off, remove the bios battery.
This will undo any changes you made.
It will also undo and system changes that make you system unique.
At least it should start working again. You can go from there.
Good luck, and don't forget to vote
Sep 27, 2010 | Gigabyte GA-K8VT800 Motherboard
Hello, I have a Gigabyte k8vm800m mobo. I get a steady amber light when I turn on my computer, but no POST and no beep.
i got the exact same problem then checked all the connections and the few jumpers i had,replaced battery, tried to get video , no onboard video, put in video card, got video once, still no beeps, retried to set up hd and install windows...then everything went at once, no beeps...never again...this was installed in a net pc with 1.5 gb memmory, board, no beeps, tried reinstalling chip and fan, power supply, checked all jumpers and wiring,,,all i can do i s replace motherboard i guess, must have shorted somewhere or kilt bios / cmos...
Jun 10, 2010 | Gigabyte GA-K8VM800M Motherboard
Post problem
You could try a program like EZ-Flash to flash the bios without using a dos disk. Gigabyte should have some type of program on their website that would do the flashing without makeing a disk as most new computers do not have a floppy drive nor does Windows XP/Vista use dos. Hope this helps.
Dec 18, 2008 | Gigabyte GA-K8VT800 Motherboard
Ga-k8vt800m motherboard specs..
First, remove all power from motherboard, including the Power Supply ATX plug. Then remove ram and all PCI and PCI-E / AGP (Video) cards even network cards... Let it sit for about 5 minutes and then plug in the necessities: RAM, Video Cards and if nothing works repeat the process but alternating ram slots and ram.
Dec 10, 2008 | Gigabyte GA-K8VT800 Motherboard
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
The best thing to do in this situation is to build your machine outside of the case, using the minimum amount of hardware,
Remove the motherboard and using only one stick of ram, the monitor, keyboard and mouse. short the power switch connector on the motherboard with a screw driver for a fraction of a second just to power it on.
If it starts up and gives you a "no boot disk" or "no Operating System found" at least you will know it's working and you can slowly connect everything else one by one to see whats preventing it from booting.
If it doesn't start like that, remove the power cord from the power supply and remove the mother board battery for at least 15 minutes, this will clear the BIOS and set it back to factory spec, now carryout the out of case procedure already stated.
Jul 22, 2008 | Intel Motherboard
GA-8VM800M-775 WILL NOT START UP
Pete, did you try the onboard video, also?
When you tried the add-on video card, did you change the setting in the BIOS?
Jan 15, 2008 | Intel Motherboard
Gigabyte GA-K8VT800 Motherboard Logo
173 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
