Question about Akai PDP4225PM Television
Akai PDP4225PM 42 Inch Scrambled Picture At all times. Good Sound
No matter What Video ... even in the boot up the Akai screen is scrambling.... Any Clues on what it could be... It just started doing it on its own.
Pics of Issue...
http://i437.photobucket.com/albums/qq97/KevinZiebarth/IMG_2412.jpg
http://i437.photobucket.com/albums/qq97/KevinZiebarth/IMG_2413.jpg
http://i437.photobucket.com/albums/qq97/KevinZiebarth/IMG_2414.jpg
  • daddy1129 Apr 22, 2009
    I have the same issue for the most part. The set comes on and the screen is fine for about 10 min's or so before it starts bouncing around with a similar view as your pics. I let it sit there a bit longer to see if whatever is failing would just go out and give me an indication on the circuit board but no dice. It did shut off on its own after about another 15 min's of sitting there. From the posts I've read throughout the web, the circuit board seems to be the issue.... This original post was from almost 5 months ago and I'm hoping someone has the answer by now. Also would it be the sub powers supply or the main power supply if infact that is the issue?
SOURCE: Akai 42" LCD has lines on start up
I got the same problem on a LCT42Z6TM. It is related to video, occurs on VGA, S-Video and Video Ports.
Posted on Aug 30, 2007
SOURCE: Akai LCT42Z6TN
I had the exact same problem already and my LCD is less than 8mo old. One of the techs from AKAI told me that its a known problem and many tv's were coming back "unserviceable". They now have a "supposed" fix for the problem. I only hope it really works and its not just a "carry-over" until the warranty ends. I am beginning to think its a quality issue and the units may just be defective. Thismay be thier way of doing a quick-fix vs. recalling all those tv's. This is what he gave me to as a solution to give the serviceman when he comes to fix the LCD.
AKAI model LCT42Z6TM: If there is no image or a badly distorted image with horizontal static lines, usually with four boxes in all four corners of the screen, there is a possible fix for this. There are four capacitors on the main board that have been identified as the primary cause of this symptom. Replace the capacitors at location numbers C280, C302, C320, C323 - 100UF 35 VOLTS [dxh]
Posted on Dec 28, 2007
SOURCE: akai lct42z6tm
I had the same corner squares/scrambled display problem in a set just over a year old (of course). It became completely unusuable and I was not looking forward to a repair bill of hundreds of dollars. After reading these posts, I opened the back of the set and took out the board with the connections on it. (FYI, the cable connections were all hot glued down, but this did not present a problem - a little wiggling and they came free. I also took lots of digital pictures to make sure I reconnected it correctly.) This board had the four capacitors (C280, etc) mentioned in this section. Since I have not had any experience with soldering on electronic boards, I found a friend of a friend who was a techie and he agreed to look at the board. He replaced the 4 mentioned capacitors - although he said they seemed to be fine. He did, however, also notice that capacitor C336 in the same area of the board was bulging so he replaced it. SUCCESS. The TV is again working fine.
So if you are reasonably handy with a screwdriver, taking out the board is easy and makes transportation a lot easier than taking the TV to someone. The cost of replacing a few capacitors on a board was minor, and in fact, if I hadn't found someone with electronic soldering experience, I would have given it a try myself. You may, however, want to check for bulging capacitors (indicating a problem) rather than just replacing the ones mentioned.
Posted on Jun 10, 2008
  • 8 Answers
SOURCE: Akai 42 inch plasma
Try putting a fan on the back of the tv to see if it is getting better. If it does then you probally have a board that is overheating. If that is the case then CAREFULLY !!! remove the back and place where you can turn on and safely access the open back NO TOUCHING STUFF !!! Mabey lay it face down on a glass table or lay it on a table with 25% hanging over the edge to see the screen. Then take a COLD blow dryer and blow it on the boards to find out which one makes it get better. If one does then it will probally be your problem board. Make extremely sure that is the one before removing it by blowing from all angles on the boards around it without air hitting the suposed problem board. Then try a little hot air to see if that starts the problem on that board so you can be sure. Of course check the surrounding and offending board several times to be sure before removing.
Posted on Jul 12, 2008
  • 3 Answers
SOURCE: no picture akai 42 inch plasma
I have not solved problem, although I paid you to solve it many months ago. The information I paid for was not the problem although the answer I was given was someone telling me it was for sure the problem.
Posted on Oct 04, 2009
Scrambled screen
could be any number of things... Bad cable, intermittent connection, bad video card. . . not enough info here to diagnose the problem
Aug 31, 2014 | Dell OptiPlex GX620 PC Desktop
Toshiba 61 inch rear projection scrambled picture for 10 minutes after power on, then clears up.
If you are seeing lines and or noise for the first several minutes and it goes away--I think I know what the problem is.
Has the period of time before it clears up been getting longer and longer?
Reply to me with the exact model number and I will tell you what is wrong and what has to be done to fix it.
A lot of these sets have problems with what is called a HYPER board----it controls all signal inside the set--confirm Toshiba and exact model number---
I am here to help people and I do this here for free.
REGARDS, SD TECH
Oct 31, 2009 | Toshiba 42H81 42" Rear Projection...
Scrambled LCD tv picture
I would think its a T-con bard fault its the main board for the screen over time they ware out from heat. this control the picture for the screen. they can go in many ways, black screen mixed or shadows even star screen and scramble type screen. and white lines and even half working only.
Jun 07, 2017 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Samsung HLP5063W 51 inch DLP is 4 years old. Screen scrambled?
there is a complete section in the tv that translate the different resolutions from the different out side video sources you normally use to the TV native resolution. That area has to be replaced. Is a module repair needed. Don't get scare. now days this kind of repair is normal and has to be included in the repair price to see if is economical to repair.
Mar 19, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I have this akai tv model lct42z6tm and connected to a vcr video output to the video input of the tv.it works for about 2 minutes and suddenly it shows grayish horizontal lines and the it scrambled all...
You may have bad capacitors on the main board where the signal is processed. These caps are as labeled: c280,c323,c302 and c320- replace this one first (it usually fixes the problem) Replace these caps with 100uf @35V
Feb 21, 2009 | Akai LCT42Z6TA 42 in. LCD Television
TV picture scrambled and getting worse
This can be a fault in the tuner, IF, or primary part of the video processing. With age and use some of the parts, and especialy capacitors, in these sets can become thermo sensitive and unstable.
To service these types of faults can be very time consuming. On top of this would be the cost of the parts.
Considering the age and type of set that you have, I would suggest that it is time to be looking for a new set.
Jerry G.
Apr 21, 2008 | Toshiba 50H82 50" Rear Projection...
Picture is scrambled hook up hdmi cable in picture still goes out. what can i do
Jan 14, 2008 | Akai LCT4216 42 in. LCD Television
Akai LCT42Z6TN
Dec 12, 2007 | Akai LCT4216 42 in. LCD Television
Aug 25, 2007 | Akai LCT4216 42 in. LCD Television
Televison & Video Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
