Question about Xerox DocuPrint 3210DX Laser Printer
How to reset the Xerox DocuPrint 32100 Chip
Any one know how to reset the Xerox DocuPrint 32100 Chip or
modify the printer not control by the chip?
  • 241 Answers
We have reset software for xerox 3210 printer. www.nakshatraworld.com
Posted on May 28, 2010
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
How to refill fuji xerox docuprint p205b toner cartridge
Need to know how to refill the cartridge for xerox p205b , please email to me : myprinterwork@gmail.com . toner and chip also i got
Sep 05, 2012 | Fuji Office Equipment & Supplies
Xerox Phaser 3500 - installed new toner still says it needs replaced. Is there a way to reset the message? We have powered off/on and it still says that it needs replaced.
the only way to reset the message is to replace the cartridge CHIP with new one or reset the chip with proper CHIP reseter(but i don't think that you have reseter).
This printer can write on cartridge chip and sometimes when you replace cartridges the printer writes directly the information from empty chip to new chip and that makes new chip EMPTY. This is some kind of bug. SORRY!!! CHIP is cheep so don't worry...be happy
pifonski
Mar 03, 2011 | Xerox Phaser 3500/DN Laser Printer
How to reset the xerox phaser 7500 chip?
I ´m searchingfor the same answer. I have been refilling the toners but now it seems thatthey reach the limits, so the printers is asking me for a new toner. I knowthat you can find from alibaba.com the reset chips. If I have any news I'llposted, please do the same.
Nov 15, 2010 | Xerox Phaser 7750DN Laser Printer
How do I set my Xerox Docuprint 3290FS colour printer to work without colour cartrige
unfortunately this cannot be done - best you can do is source a replacement chip for the
cartridge - worst, replace the cartridge with either a compatible or genuine one
Aug 13, 2010 | Xerox DocuPrint C3290 Printer
Red light at paper always on
it is problem your printer cartridge sensor chip change it
Jul 13, 2009 | Xerox DocuPrint 203A Laser Printer
Xerox Docuprint C1618 Colour Laser
Are you certain you have typed the right model number? I can't find a Xerox 1618 anywhere. I would love to help.
Mar 24, 2008 | Office Equipment & Supplies
Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Jan 15, 2008 | Xerox Phaser 8500/DN Printer
Xerox DocuPrint 3210DX Laser Printer Logo
796 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
