Question about Dell OptiPlex GX280 PC Desktop
Dell gx280 wont boot
Power button Solid Orange and system sounds running but nothing showing
  • Anonymous Dec 27, 2008
    I support about 150 GX280 and I was calling Dell for warenty fix on this.. If you look at the motherboard the resisters burst open and leak some kind of liquid redering it usless. Check with Dell you might be covered for this...
  • Anonymous Mar 12, 2014
    solid orange start up button but PC wont boot up
    President:
  • 2,992 Answers
The power supply might be defective, but usually this means a bad system board. Any other kinds of problems would allow the system to at least boot, but this one isn't getting even that far.
Unfortunately, the Dell case uses a proprietary motherboard, so you will need to get the same one if you want to replace it.
Posted on Dec 10, 2008
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
Dell GX280 orange light on MOBO
Dell Support > Optiplex GX280 Desktop PC > User Manual,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tindex.htm
I chose the Mini-Tower model because the following information applies to all models;
Small Form Factor (SFF)
Small Desktop
Desktop
Small Mini-Tower
Mini-Tower
Computer and Software Problems > Troubleshooting Tools and Utilities > System Lights,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm#wp1114432
Now scroll down. What do the Diagnostic Lights indicate?
Post back in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | Dell OptiPlex GX280 PC Desktop
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
OPTIPLEX GX280 BIOS UPDATE NOW SYSTEM WONT START. ORANGE LIGHT SHOWING ONLY! Before the upgradation, My system was working perfectly fine. After the installation. My system is not working and the orange...
You need a start-up CD and re-flash the Bios to Factory settings that worked. Best guess would be something was wrong with the BIOS package you had installed or someone/something messed up the installation which is causing your problem.
If you have factory CD Try to start the computer with that in.
Jul 20, 2009 | Dell GX280 Optiplex 2.8GHz Desktop...
Pc does not always boot up
A solid or blinking Amber power button indicates a voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 21, 2008 | Dell OptiPlex GX280 PC Desktop
Dell Optiplex GX280 boot problem
I just repaired two Gateway systems with similar behavior (turn on power, fan runs at full speed, no boot), and both needed replacement system boards. (These were a different model, but the symptoms are typical of a dead system board.) I got the boards from a company called Blue Raven Technology (www.blueraven.com).
Before deciding the main board is bad, try another power supply to make sure that's not the problem. Also you might try clearing the CMOS memory on the system board (either by moving a jumper usually found near the backup battery, or by removing the battery itself). Sometimes corrupted CMOS data will keep the system from booting.
Nov 16, 2008 | Dell OptiPlex GX280 PC Desktop
Dell GX 280 wont start
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Thank You.
Oct 30, 2008 | Dell OptiPlex GX280 PC Desktop
Dell Optiplex gx280 shuts down and orange power light blinks
It happens because the power supply is overheats and computer goes to standby. The power supply is 160w or lower. Specially it will happen if you put more devices in such as video card or sound card. So the only solution you have is to place a small 1or2 fans toward the power supply to make it cooler. And 1 more thing the power for the fans should come from other sources.
Sep 30, 2008 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
198 people viewed this question
Alun Cox
