Question about Sony Ericsson P910i Smartphone
Display screen on the display screen all the icons are showing . i want to hide them
  • jmed Dec 30, 2008
    I have a Lenovo Lap top. Just recently stopped showing my icons. Does not show anything on the screen except the back ground. Please help if you can how I can fix this problem.
    Thanks,
    Jesse
    Missouri
    Welcome Back:
    Visited the website for 2 consecutive days.
All you need to do is to personalized your phone..from the screen select the ALL then create a folder with nothing in it...
or
you can change the setup of your phone.. you change to view as list from edit menu
Posted on Dec 17, 2008
When phone rings it used to announce the caller ID, but now it doesn't.
Hi Steve
Find "Caller ID"
Press the phone icon.
Press the menu icon.
Press Call settings.
Press Additional call settings.
After a moment the current settings are displayed.
Press Caller ID. Turn your own caller identification on or off
Press Hide number or Show number. Return to the home screen
Press the home icon to return to the home screen.
May 10, 2016 | LG G3 VS985 32GB Verizon wireless CDMA /...
Tip
Hacking Your Way Through the Interface
Use Registry hacks to make a grab-bag of great interface changes.
Hidden in the mazes of the Registry are countless ways to hack XP's interface. Here are some of my favorites.
Hide All Icons in the Notification Area
The System Tray, also called the Notification Area, is the small area on the far-right side of the Taskbar, in which utilities and programs that run in the background, such as antivirus software, show their icons.
I don't find it a particularly intelligent use of screen real estate, so I'd prefer not to see the icons there. To hide them, run the Registry Editor [Hack #68] and go to HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer. Among other things, this key controls the display of objects throughout XP. Create a new DWORD called NoTrayItemsDisplay. Assign it a value of 1. (A value of 0 will keep the icons displayed.) Exit the Registry and reboot.
While you're at the HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer key, you can also delete the My Recent Documents icon on the Start menu. Create a new DWORD called NoRecentDocsMenu. Assign it a value of 1. (A value of 0 will keep the icon displayed.) Exit the Registry and reboot.
Hide Only Certain Icons in the Notification Area
You might like to display some icons in the notification area but hide others. If so, you can hide icons on a case-by-case basis. You'll do it by delving through menus, though, not by hacking the Registry. Right-click on the Taskbar and choose Properties → Taskbar. The Taskbar and Start Menu Properties dialog box appears. This dialog box, as the name implies, lets you control how the Taskbar and Start Menu look and function.
In the Notification area of the dialog box, check the box next to "Hide inactive icons," then click Customize. The Customize Notifications dialog box appears,
Click on the program's listing in the Behavior column, and choose from the drop-down menu to hide the icon when the program is inactive, always hide it, or never hide it. Click OK twice. Your changes will take immediate effect.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Move task bar to bottom of page
The desktop screenshot might need reducing
Click start "Control Panel."
Click "Display" and then select the Settings tab in the Display Properties window.
Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply."
The screen repaints at the new resolution.
Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
Nov 09, 2012 | Microsoft Windows 2000 Professional for PC
A simple free program that can hide/restore icons on my desktop
Hi hugh hinds....
Try this easy solution to your problem
Please take time to rate me
Hiding Desktop Icons in Windows XPWith a good choice of wallpaper, your computer desktop can add an attractive, even artistic, element to your home or office. Eye-catching desktop wallpaper can be as decorative in its way as a painting or other wall hanging.
If you value the aesthetic potential of your desktop, you might like to enhance it even further by hiding the desktop icons.
Hiding or showing your desktop icons in Windows XP is a simple, two-click procedure.
To hide desktop icons:
  1. Right-click on the desktop and open the "Arrange Icons By" sub-menu.
  2. In the sub-menu, click "Show Desktop Icons" to uncheck it.
The icons should disappear to leave a clean, uncluttered desktop. To show desktop icons again, repeat the above procedure. When the icons are hidden, clicking on "Show Desktop Icons" will enable the option and the icons will reappear.
1...Right-click on the desktop and open the "Arrange Icons By" sub-menu.
2...In the sub-menu, click "Show Desktop Icons" to uncheck it.
Aug 23, 2011 | Computers & Internet
My icons on my screen are not appearing. How you
right-click on the screen ,
point to "arrange icons by"
and click "show desktop icons"
please complete the questionaire
Oct 16, 2009 | ASUS Eee 4G Notebook
How do i recover hidden icons?
To hide a Home screen icon, complete the following steps:
  1. Select an icon on the Home screen of the BlackBerry smartphone.
  2. Press the Menu key.
  3. Click Hide Icon.
To show a hidden icon on the Home screen, complete the following steps:
  3. Click Show All.
After the Show All option has been selected, to show a hidden icon, complete the following steps:
  1. Select the transparent icon on the Home screen that you want to make visible.
  3. Cancel the Hide Icon selection.
Aug 12, 2009 | RIM BlackBerry Pearl 8100
My calendar program is missing..
IN MENU--> SELECT BLACKBERRY LOGO BUTTON--> SELECT SHOW ALL.
1.To hide a Home screen icon, complete the following steps: Select an icon on the Home screen of the BlackBerry smartphone. Press the Menu key.
Click Hide Icon.
2.To show a hidden icon on the Home screen, complete the following steps:
Press the Menu key. Click Show All.
3.After the Show All option has been selected, to show a hidden icon, complete the following steps:
Press the Menu key.Cancel the Hide Icon selection.
4.If not able to find Install Blackberry desktop Manager ...Take Backup.. reinstall the application from application loader in Blackberry Desktop Manager
Aug 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
My faves icons wont come up when 1 of my 5 calls
try a master reset.....if that does not correct the issue then take the phone to your mobile service provider for further assistance.
Feb 01, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Open Questions:
Sony Ericsson P910i Smartphone Logo
32 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
