Question about Logitech QuickCam Communicate STX Personal Web Camera
Microphone Not Working
I have a Logitech QuickCam Communicate STX and the video works just fine in Yahoo Messenger, AIM, Skype, but for the life of me I can not get my microphone to work. Is it the camera or is it the settings that I need to adjust? If it is the settings, how do I make the camera like my default setting? Any help would be greatly appreciated.
    Sergeant:
  • 320 Answers
Each one of those applications has their own settings for audio. However to make it easier, you can set your webcam as the "default" input device for audio.
To do this, click on the "Start" button then goto "Control Panel"
Once in "Control Panel" click on "Sounds and Audio Devices" Then click the "Audio" tab at the top of the new box.
Under "Sound Recording/Default Device" click the drop down menu and choose your webcam from the list.
These steps may differ slightly depending on the version of Windows you are using. But this will set your webcam as the default microphone for all applications.
Jei
Posted on Dec 11, 2008
2 Suggested Answers
ser71
  • 818 Answers
SOURCE: logitech quick cam communicate stx on Vista - microphone not working
Why isn't the microphone on my camera working?
trnsp.gif Answer The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
This article covers how to configure a Logitech camera's audio and video settings to work with Skype 3.6 or above. trnsp.gif Answer This article applies to the following cameras:
QuickCam Orbit AF
QuickCam Pro for Notebooks
QuickCam Pro 9000
This article applies to the following platforms:
Windows Vista
Windows XP
This article applies to the following 3rd party application:
Skype™ 3.6 or above
To set up Skype for video please be sure that your Logitech webcam is connected and working. This can be verifed by launching your QuickCam software and checking for a video stream withinin the QuickCapture video window. Once the webcam functionality is verified, please close the QuickCam application and follow the steps below.
  1. Launch Skype™ and click on "Tools" as shown in the figure below
    Fig 1
  2. When you click on "Tools" you will see a drop down list
    Fig 2
  3. Click on "Options" at the bottom of the drop-down list
    Fig 3
  4. A new screen appears. Click on the left side of the pane under "Video Settings"
    Fig 4
  5. Under the "Select webcam" drop down, please choose your Logitech camera, then click the "Save" button.
    Fig 5
  6. Click on "Tools" as shown in Fig 6 to get your Logitech Audio setup.
    Fig 6
  7. When you click on "Tools" you will see a drop down list
    Fig 7
  8. At the very bottom of the drop down list, please click on "Options"
    Fig 8
  9. When you click on "Options" you will see a new screen
    Fig 9
  10. On this new screen click on the left side of the pane under "Audio Settings"
    Fig 10
  11. You will now have the option to select your Logitech camera's Microphone as your main Audio source. Under the "Microphone" drop down, select the Logitech Microphone, and click "Save"
    Fig 11
  12. You should now be ready to use your Logitech webcam and microphone in a Skype video call.
Posted on Apr 03, 2008
My logitech webcam won't work in msn messenger....in messenger when i try to make a video call...it says I need to buy or install a webcam? what's the deal? heeeelp
Hi Marilyn,
Have you installed the Logitech Quickcam program? If you did then open the application and select the instant messenger(i.e. MSN, SKype, Yahoo) that you will be using the camera.
If you have note yet installed the Logitech Quickcam application then I suggest you disconnect the webcam and run the software first.
Oct 28, 2010 | Logitech QuickCam Communicate STX Personal...
I have logitech 861194-0000 quickcam,not working my yahoo mssger
i have a eton web cam but it does not work seens it was been formated......
Jun 02, 2010 | Logitech QuickCam Communicate STX Personal...
I can't get the video to work on skype. The solution said to add
If you have problems when you use your Logitech device in Skype, you may have to configure the audio and video setting in Skype. To do this, follow these steps:
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your Logitech device as the default microphone. (if it has a built-in mic) For example, select Logitech Communicate STX.
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your Logitech device as the default Webcam. For example, select. Logitech Communicate STX
  7. Click Save.
  8. Test Logitech by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site: http://support.skype.com (http://support.skype.com)
Aug 29, 2009 | Logitech QuickCam Communicate STX Webcam
Hi, i would like to take live picturs and/or video while i am chating with skype and dont know how to do it. will you help me ? thanks, eddie
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Skype issues with your QuickCam Communicate STX trnsp.gif Detailed Description 1754.1.0.jpg This article explains what to do if you have problems using Skype with your QuickCam Communicate STX.
Model Number: V-UBK45
trnsp.gif Answer If you are experiencing difficulties using the QuickCam Communicate STX with Skype, check the following:
Verify the QuickCam Communicate STX is functional:
  1. Launch QuickCam software (Start > Programs > Logitech > Logitech QuickCam)
  2. Verify that you can see yourself in the QuickCam window as shown below:
  3. Close the QuickCam window.
Verify that the QuickCam Communicate STX is selected in the Skype Settings:
  1. Launch Skype (Start > Programs > Skype > Skype)
  2. Click Options from the Tools menu as shown below:
  3. Select the Video Settings option from the Skype sidebar as shown below:
  4. Check the Enable Skype Video checkbox as shown below:
  5. Check the "Start my video automatically when I am in a call" checkbox as shown below:
  6. Verify that your QuickCam Communicate STX is selected from the Camera drop-down menu as shown below:
  7. Verify that your QuickCam Communicate STX is selected from the Microphone drop-down menu as shown below:
  8. Verify that the "Let Skype adjust my audio settings" option is checked in Audio Settings as shown below:
If you still cannot see or hear the other person, it can be due to a variety of possible issues, including:
  • Windows or third-party firewalls
  • Your internet service provider (AT&T, Comcast, etc) could be blocking certain services.
  • Missing Windows system components.
Jan 10, 2009 | Logitech Quickcam Chat Webcam
VX3000 webcam not working on AIM
Go to the Audio Setup and make sure your audio card is selected. Then it should work. Hope this helps. Bud
Dec 29, 2008 | Logitech QuickCam Communicate STX Personal...
Webcam is not working with yahoo messenger
See section B. Yahoo in info below.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Dec 01, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech quick cam communicate stx on Vista - microphone not working
QuickCam Orbit AF
QuickCam Pro 9000
Windows Vista
Windows XP
Skype™ 3.6 or above
    Fig 1
    Fig 2
    Fig 3
    Fig 4
    Fig 5
    Fig 6
    Fig 7
    Fig 8
    Fig 9
    Fig 10
    Fig 11
Mar 25, 2008 | Logitech QuickCam Communicate STX Personal...
My Logitech quickcam STX works only with mic webcam or mic with yahooIM
A. Skype Setup:
B. Yahoo Setup:
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
Mar 01, 2008 | Logitech QuickCam Communicate STX Personal...
Built in Microphone doesn't work in AIM, Windows Live Messanger
You would be surprised at how many people don't realize that each application has it's own configuration screen.
It's not the end-users fault - like you said... the instructions could be a BIT more clear.
Feb 12, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech QuickCam Communicate STX Personal Web Camera Logo
282 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
