Question about TallyGenicom 8008 Laser Printer
Tally Genicom 8008
We have 2 printers in our school and both are exhibiting the same problem. Halfway down the printed page (A4) a ghost image is superimposed on the original. Both machines have had the photosensitive green belt replaced and there is no sign of any residual image on either of them. Is it possible that the problem is with the main drum and if so how do I fix it.
    Novelist:
  • 169 Answers
The residual image often occurs if the Transfer Drum cleaning roller is not located correctly in the printer, as this cleans the previous image of the transfer drum. In some cases where the printer has been moved or shipped, this cleaning roller may need to be relocated in the printer to ensure it is in contact with the transfer drum.
I believe the cleaning roller on the 8008 is located just behind the OPC belt, try removing this and clean the contacts at each and of the cleaning roller.
Ensure the cleaning roller fits back in the printer ok and give it a try.
Posted on Sep 21, 2009
Why can't I print through a Tally T5040 printer?
Tally genicom 5040 passbook printerre download the drivers and make sure you have a good connection (USB )
Mar 21, 2012 | Office Equipment & Supplies
Hi I have a second hand Tally Genicom 8008 and I can't get it to print anything. I've just downloaded a printer driver for it and am using it with an iMac with OS X Leopard. When I send something to...
First is worth checking the C (cyan) toner is not causing the problem with printing, the easiest way to do this is to print a configuration or test page via the menu on the printer to see if it will print. If the printer will print a page via its menu it should then be capable of printing from the computer system,
The Menu / Test Page can be printed in the following way;
  • Put the printer OFFLINE
  • Press the MENU/ENTER button
  • The display should read
The printer should print a page, if it does not it sounds like the cyan toner is empty and is stopping the printer printing.
If the Menu / Test page prints ok this indicates the problem may be connectivity or driver related.
The first thing I would say is there are issues with printing to the the 8008 from Mac's particularly with the Intel processors.
There are also issues with versions 10.4 and over.
Some suggestions,
  1. Print using TCP/IP, ensure the printer has a IP Address set and also the port on the Mac is set to the same IP address. (dont use Apple Talk)
  2. Ensure you have the driver for the 8008 (not the IP8008) the IP8008 driver will not print to the 8008 and vice versa.
  3. Try printing from a simple application for example Sticky Notes, just to see if the problem may be down to the size of data files.
Apr 06, 2011 | TallyGenicom 8008 Laser Printer
I need a linux driver for tally genicom 8008 colour printer. Does anyone have one? or know where to get one?
I have the same printer and run Linux Mint 13. Here's what I did:
Went to http://foo2slx.rkkda.com/ and followed the instructions for installing a Lexmark c500n.
Opened a browser and went to http://localhost:631 (the CUPS admin page).
=> CUPS for Administrators => Adding Printers and Classes
Add printer.
Follow the instructions until you reach a page with "Or Provide PPD File" at the bottom. Click "Choose File".
Navigate to where you unpacked the foo2zjs driver, there should be a folder in there called PPD: you want Lexmark-C500.ppd
Set what defaults you want do some printing.
When you have finished marvelling, perhaps give a thought to donating to the chap at foo2zjs for his hard work...
Jul 19, 2010 | TallyGenicom 8008 Laser Printer
T6312
The problem coming from your logic card hammer bank cable . Need to be replace logic card and hammer bank cable.
May 19, 2010 | TallyGenicom 6312 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Tally Data Recovery
I suspect you do not have a problem with a TallyGenicom 8008 more likely with a the Tally Solutions ERP system check the following page for tallysolutions contacts and support
http://tallysolutions.com/newwebsite/html/index.html
May 30, 2009 | TallyGenicom 8008 Laser Printer
SVC E9 ERROR
butta via la stampante e prendi una hp
Jan 17, 2009 | TallyGenicom 8008 Laser Printer
I own a Tally Genicom 8008 Laser printer. From the last print and after it appears the message: SVC E9 ERROR
The error indicated on the 8008, ‘SVC E9’ indicates the printer is not detecting the OPC Belt as rotating in the printer. The printer ‘looks’ for two black squires on the left side of the OPC Belt (as viewed from the front of the printer) if the printer does not ‘see’ black squires the printer indicates the SVC E9 error.
If the printer is displaying the SVC E9 error the most likely cause is something to do with the OPC Belt, normally removing the OPC belt from the printer then re-seating the belt would resolve the problem in most cases, as the OPC belt may not be locating correctly in the printer.
Unfortunately you have already removed the OPC Belt from the printer without resolving the problem, it may however be worth removing the OPC belt again and to look at the green reflective surface to see if there any damage or if the green surface is fairly central and is no skewed or bent in any way.
Depending on which position the OPC belt stops in you may see the black squares down the left side of the belt, if you can see these and they don’t look damaged or scratched the printer should detect the OPC belt ok, so the problem may lie with the sensor on the printer its self.
Tally 8008 not printing mac OSX 10.5.6 leopard
Found a solution. We connected 8008 printer to imac running Tiger & we can now print via network on any of our emacs running Leopard. Not ideal but at least we can now use the printers. I would still love a dedicated driver to work direct but I suppose this will do for now.
Jan 13, 2009 | TallyGenicom 8008 Laser Printer
Tally Genicom 8008 ghosting
replace whole cartridge, if problem still exist then you have go fuser roller ( heat roller ).
Dec 10, 2008 | TallyGenicom 8008 Laser Printer
TallyGenicom 8008 Laser Printer Logo
158 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
