Question about Microwave Ovens
Fan & Turntable start when door is opened.
After using the convection feature, I now have two problems. First, when the door is opened the fan and turntable come on. Second, in trying to simply use the MW function - when the door is closed and MW ''starts'', nothing happens except that the timer counts down. No light comes on, no turntable motion AND no MW heating.
Has my 12 year old GE JE1390 MW died?
  • gsmithnovus Dec 13, 2008
    In replacing the microwave it became apparent that GE makes it impossible to find a new model that will work with an old Trim Kit. I was able to find a new Kenmore model 721.67902 that was very close. With a bit of manipulation (grinding off a 1/4' flange on the sides of the trim face) - it fits fine and looks great.
  • 36 Answers
Sounds like there is a switch that is bad. you can go buy a new MW for about 200$ and in yours if there is a major problem then i would just go buy a new one but might be worth a repair man to come check it out
pleas do not poke around in the microwave as it carries a charge of 5000volts and can kill you even if not plugged in DON'T TOUCH THE WIRES WITH BRAIDS ON THE OUT SIDE if you must get inside of the unit
Posted on Dec 10, 2008
Fan runs when door is closed and no time set.
Some GE units were starting on their own. I would definitely unplug this oven and call GE to make sure yours wasn't one of the ones being re-called.
Feb 14, 2013 | GE Advantium 120 Convection/Microwave Oven
Jenn-air micro convection - cooling fan comes on when door is opened, then goes off, intermintent problem
I have seen where one of the door switches becomes intermittent causing the symptoms you are describing, tough to nail down considering there are more than one door switches.
Jun 16, 2012 | Jenn-Air JMV9169B Convection/Microwave...
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
Not Heating. Fan, turntable, light working.
I would definitely suspect the door locking mechanism in this case. If it was the sensor it would start and then stop within a short time.
The starter switch should click if you have the door open and time it for 01.seconds and press start. So that is the secon component to think of.
Nov 26, 2009 | Sharp R-930AK Convection/Microwave Oven
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
Turntable won't stop
Sounds like a door switch problem or stuck relay contacts on the control PCB. Do the light and fan run too or just the T/T??
Nov 07, 2008 | Jenn-Air JMC9158AA Convection Microwave...
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Does Not Shut-Off Completely
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 05, 2008 | Amana ACM1580 Convection Microwave Oven
Fan runs and turntable turns when door is opened
SRUte- This sounds as if you have a collapsed door switch, this would cause this problem,I would not recommend using it until repaired. But as far as recommending a good brand,each to his own everyone is different.I have done repairs for years,and I Love Panasonic products,they seem to have minimal problems.I hope this helps you out. cooltek Mar,3/08
Mar 04, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
204 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
