Question about Sony DAV-SA30 System
Noise and distortion on sound
Around the 15 minute and 50 minute time the system starts making a popping noise and then distorts the sound when watching Sky and or Video and or Tv but not dvds direct thru the TV. It has been suggested that there is some sort of feedback via the cable or scart setup, but I am at a loss of how to sort this out. Martin Moss.
  • tabby1 Mar 16, 2008
    When the unit has been left on, or when playing copied music CD's there is a distortion in the sound it becomes muffled, crackling and popping, can anyone help me?
Thanks for the solution, but it is only tempory. It stops the noise but keeps coming back. The audio conections seems to be the problem but these have been checked out and are OK.
Posted on Mar 29, 2007
DO CHANNEL SETTING OR AUTO SCANNING THE PROBLEM WILL GO
Posted on Mar 22, 2007
SAMSUNG 50 INCH PLASMA MAKING A CLICKING NOISE,NO BAD POER SUPPLY REPLACED BUT STILL MADE THE SAME NOISE??
Unhook the cable going from the power board to the buffers one at a time and see if it comes on then with a distorted picture or at least sound, replace that board
Mar 15, 2018 | Samsung Televison & Video
At low volume it is fine after you get to about 20 on the volume it starts to crack,pop and distort very bad what is making this happen
Your speakers may say 350 watts but that is the peak wattage at which they blow up and not a wattage they can sound distortion free at. Look for the RMS wattage which is probably around 40 watts. If you look at the specs on your receiver you will see it will put out a maximum of about 50 watts but the distortion on the receiver is above 1 percent at anything over 22 watts. That means they are going to start distorting at around half volume. The other thing you might check for is a impedance mismatch between the speakers and the receiver. Is the receiver set up for an impedence output of 8 ohms but your speakers are 4 ohms impedance.
Aug 23, 2015 | Kenwood KDC248U CD Car Stereo Receiver...
Monitor distorts colors and goes out of sync horizontally after 15 min
they dont last forever... time for replacement as most are not user-serviceable..
Mar 08, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
Vr-309 starts to clip after 10-15 min
This is a case of one or more transistors breaking down when heated. This can be found usually by using freeze spray to cool down one transistor at a time until the problem clears up. You can narrow this down a bit by determining whether this "noise" is effecgted by the volume control or not. Also, does the problem show up faster when the unit plays louder?
Dan
Aug 29, 2008 | Kenwood VR-309
US-144 noise
Hi
Usually Noise comes from distortion such as Electricity (50-60Hz), Main reason audio input cables might have shielding problem. Make sure cable is connected well and shield is not destroyed. You can understand it when you unplug the input connection and use the Computer volume by playing a digital media. If distortion persists contact to TASCAM @+1-323-727-7617
Good Luck
Jan 11, 2008 | Tascam US-144 Sound Card
Polk subwoofer making crackling noises
Yea, now its time to replace it! the magnetic effect is weaken which makes the very bass low frequency sound to be distorted! You should re engergise the magnet of the subwoofer or should buy the new!
Dec 08, 2007 | Infinity BU-120 Subwoofer
High pitch ringing noise and picture distortion
Sounds like the capacitor that goes bad just before the hIgh Voltage transformer goues bad. If i were you I would call an authorized RCA repair Shope and see if this is going to cause more damage to your set in the future.
Aug 25, 2006 | RCA HD52W59 HDTV Projection Television
Sony DAV-SA30 System Logo
234 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
